| New Reply |
[SOLVED] Riding a Loop the Loop (velocity at the bottom of the loop) |
Share Thread | Thread Tools |
| Feb25-08, 12:58 PM | #1 |
A car in an amusement park ride rolls without friction around the track shown in the figure. It starts from rest at point A at a height h above the bottom of the loop. Treat the car as a particle. ![]() part A - What is the minimum value of h (in terms of R) such that the car moves around the loop without falling off at the top (point B)? found this to be 5/2R, since: sigma Fy = Fc - N - mg = 0 N = 0 and Fc = mv^2/R so Fy = Fc = mg and mv^2/R = mg and v^2 = GR h = (1/2mgR + 2mgR)/mg = 1/2R + 2R = 5/2R now I'm stuck on the velocity at the point C. part B - If the car starts at height h = 4.50 R and the radius is R = 22.0m , compute the speed of the passengers when the car is at point C, which is at the end of a horizontal diameter. 2. Relevant equations mgR = 1/2mv^2 v^2 = [tex]\sqrt{2mgR}[/tex] 3. The attempt at a solution got v = 29 which was wrong, I might be using the wrong formulas or the wrong radius, or the formulas in the wrong way; this is an energy conservation problem. any help is appreciated. |
| Feb25-08, 01:25 PM | #2 |
another method I tried, was that:
h = 9/2R = 99m so the conservation of energy equation would turn out to be: mgh = 1/2mv^2 v^2 = 2mgh/m so v = [tex]\sqrt{2gh}[/tex] = 44m/s, which also turned out to be wrong. |
| Feb25-08, 03:15 PM | #3 |
Your h=2.5R looks good for part A. For part B, you are neglecting the fact that the coaster has speed at the top of the loop in your first attempt,; in your second attempt, you neglected it has PE at point C, if you used h=4.5R.
| Feb26-08, 07:19 PM | #4 |
bump to this, I figured out how to solve the velocity, got 38.8m/s and found the radial acceleration to be 68.6m/s^2.
now I want to find the tangential acceleration, I don't know angular velocity formulas at this point, so not sure where to take the problem to find the tangential acceleration, the only thing I know would be that it would be pointing outside the loop, but not sure how to write that mathematically. |
| Feb26-08, 07:29 PM | #5 |
forget it, lol, I solved it,
atan = v^2/R = gR/R = g |
| Oct10-11, 12:26 AM | #6 |
erm...I just wanted to say that the reply above mine solving for the tangential acceleration is not proper.... v^2/r is for *centripetal* acceleration, or radial acceleration (pointing towards the center of the circle). The tangential acceleration is "g" because the vector is pointed straight down and the only force to accelerate the object of our interest is gravity. To find the tangential accel. in a situation like this, you must multiply the acceleration of gravity (g) by the cos(angle respect to vertical).
| Mar12-13, 05:39 PM | #7 |
I do see that the loop exerts a normal force which is downward but why is this force equal to 0? |
| Mar12-13, 05:42 PM | #8 |
Should not the force F_{c} be directed along the trajectory since it is just the mass(scalar)*acceleration(vector) and acceleration has two components; One to the center of the orbit and one along the trajectory.
| Mar12-13, 06:11 PM | #9 |
Mentor
The analysis should be: ƩFy = Fc = -N -mg |
| Mar12-13, 06:23 PM | #10 |
It is something with the signs..If we proceed with ƩFy=Fc=-N-mg=-mg and use that Fc=mv^2/R we obtain that v^2=-gR which is wrong since (g,R)>0. |
| Mar12-13, 06:30 PM | #11 |
Mentor
ƩFy = ma -N-mg = -mv^2/R |
| Mar12-13, 06:42 PM | #12 |
h=(1/2mgR + 2mgR)/mg is clearly equivalent to mgh=(1/2mgR + 2mgR) which means that the potential energy at beginning (mgh) is equal to mg2R(top of the circle)+mgR/2 (the difference from in energy from initial position and on top of the circle). How do we know that difference is mgR/2? |
| Mar12-13, 06:57 PM | #13 |
Mentor
And since you just determined that mv^2/R = mg at the top, you know that the KE = 1/2mv^2 = mgR/2. |
| Mar12-13, 07:15 PM | #14 |
| New Reply |
| Thread Tools | |
Similar Threads for: [SOLVED] Riding a Loop the Loop (velocity at the bottom of the loop)
| Problem 7.46: Riding a Loop-the-loop | Introductory Physics Homework | 0 | ||
| [SOLVED] Loop the Loop | Introductory Physics Homework | 8 | ||
| Work done by mass on a loop-the-loop track | Introductory Physics Homework | 10 | ||
| Bead and loop-the-loop: normal force?? | Introductory Physics Homework | 4 | ||
| Loop-the-loop normal force | Classical Physics | 8 | ||
