Rolling motion including torque and acceleration
A uniform solid cylinder lawn roller experiences a constant horizontal force while rolling without slipping. The acceleration of the center of mass can be derived as \(\frac{2\vec{F}}{3M}\), and the minimum coefficient of friction required to prevent slipping is \(\frac{F}{3Mg}\). The discussion highlights the need to analyze the forces and torques acting on the roller, particularly focusing on the torque about the center of mass. Participants suggest using a force diagram to clarify the relationships between forces and motion. Understanding these concepts is crucial for solving the problem effectively.
XxBollWeevilx
A constant horizontal force \vec{F} is applied to a lawn roller in the form of a uniform solid cylinder of radius R and mass M. If the roller rolls without slipping on the horizontal surface, show that (a) the acceleration of the center of mass is \frac{2\vec{F}}{3M} and (b) the minimum coefficient of friction necessary to prevent slipping is \frac{F}{3Mg}. (Hint: Take the torque with respect to the center of mass.
Not quite sure.
Well, this is my last problem of the night to finish. To be honest, i have no idea where to begin. I don't know how to examine the acceleration or how to use torque to find friction. Any step in a positive direction would be helpful. I appreciate it.
I was thinking maybe a force diagram...but I'm not sure how it would apply to the rolling motion.
Also, I'm not sure whether the applied force is causing any torque or not.
