Energy-Momentum Tensor: Exploring Einstein-Hilbert Action
lion8172
I was wondering if someone could clarify something that I read in a book (Nakahara's book on Geometry, Topology, Physics). In the section on the Einstein-Hilbert action, the author defines the energy-momentum tensor as
\delta S_M = \frac{1}{2} \int T^{\mu \nu} \delta g_{\mu \nu} \sqrt{- g} d^4 x.
Shortly thereafter, he then writes that, "for example, T_{\mu \nu} of a real scalar field is given by
T_{\mu \nu} (x) = 2 \frac{1}{\sqrt{-g}} \frac{\delta}{\delta g^{\mu \nu} (x)} S_s = \cdots.
My question is, where did the integral over dx^4 go?
The functional derivative of the actions is defined by
\delta S = \int d^{4}x \frac{\delta S}{\delta g^{ab}} \delta g^{ab}
regards
sam
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
