What is the distance between star 1 and 2 if the net force of star 2 is zero?
  • Thread starter Thread starter minimax
    Astronomy
The discussion revolves around calculating the distance between star 1 and star 2 when the net force on star 2 is zero. It is established that the forces acting on star 2 from stars 1 and 3 are equal, leading to the equation F = Gm1m2/x^2 = Gm2m3/(D-x)^2. Through manipulation of these equations, the relationship between the masses is clarified, with m3 being 7/4 of m2. Ultimately, the distance x between star 1 and star 2 is determined to be D/5 after resolving the equations. The participants express confusion over the calculations but arrive at a consensus on the final result.
minimax
Astronomy Que!
Three stars lie on a line (1,2,3). The distance from star 1 to star 3 is labelled as D. If star 1 is four times that of star 3, and seven times of star 2, what is the distance between star 1 and 2 if the net force of star 2 is zero?
F=\frac{Gm1m2}{r^{2}}
Since the net force for star 2 is zero, I know that the force between star 1 and 2 is the same as the force between start 2 and 3
\frac{Gm1m2}{r^{2}}=\frac{Gm2m3}{r^{2}}
I tried to sub in values to find the force between star 1 and 3
F=\frac{Gm3(4m3)}{D}
but I'm not sure where to go from here...
Thank you
m_1=4m_3=7m_2
So then, the distance between star 1 and star 2 is x, and the distance between star 2 and star 3 is D-x. Can you go on from here?
errr..I think so.
Here's what I've 'tried' so far
\frac{Gm1m2}{x}=\frac{Gm2m3}{D-x}
\frac{G7m^{2}}{x}=\frac{Gm2m3}{D-x}
Cross multiply:
\frac{G7m2^{2}}{Gm2m3}=\frac{x}{D-x}
G's cancel, so do m2
\frac{7m2}{m3}=\frac{x}{D-x}
if 4m3=7m2
then m3=(7/4)m2
so,
\frac{1}{4}=\frac{x}{D-x}
now to find for x?
(D-x)=4x
D-x=4x
D=4x+x
x=\frac{D}{5}
not sure if it's the right way, or if I'm just messing around with variables, or if the force between 1 and 3 has any use (yikes!)
Anyone willing to verify?
but yeeeah...times like these when I wonder why I took physics as an option when I'm planning to do arts *sighs*
thanks for your help!
minimax said:
if 4m3=7m2
then m3=(7/4)m2
so,
\frac{G}{4}=\frac{x}{D-x}
1. Where did that G/4 come from?
2. F \propto \frac{1}{r^2}
whoops, the G's cancel out too
I got the 1/4 from dividing G7m2 by G(7/4)m2
so...\frac{1}{4}=\frac{x}{D-x}
to get x=D/5
if 4m3=7m2
then m3=(7/4)m2
so,
Does \frac{7m_2}{m_3}=\frac{1}{4} when m_3=\frac{7m_2}{4}?
You also haven't addressed my 2nd point.
shizz..
no, it is not 1/4...but 4 instead
4=\frac{x}{D-x}
as for your second point: the inverse proportionality of distance to Force...
the larger the distance, the smaller the force...
But it's not distance, it's distance squared.
so what you're saying is that I have to square my x and D-x values right?
Well, if the formula is given by F=\frac{Gm_1m_2}{r^2}, should you?
merde. i feel like I am going around in circles...
ok, so if i squared it
4=\frac{x^{2}}{(D-x)^{2}}
square rooting it, i get
2=\frac{x}{D-x}
cross multiplying and expanding...
x=\frac{2D}{3}
Looks good to me.
yay! thanks for your help and patience Snazzy!
