12v to power household appliances?
  • Thread starter Thread starter jagman454
    12v Power
To power household appliances like computers and TVs with a 12v battery, an inverter is necessary, as these devices typically require 100v from a standard outlet. A sine wave or modified sine wave inverter is recommended for compatibility with electronic equipment. Deep cycle batteries are ideal for this purpose, providing longer usage times, but running appliances for extended periods will require a significant investment in batteries. Inverters can range in power from 400 watts to 2000 watts or more, with prices varying by supplier. For reliable options, specialized retailers and RV dealers are good sources for purchasing inverters.
jagman454
12v to power household appliances??
How can I use a 12v battery to power household appliances such as computers/TV ect...
Do I need some type of converter? I was told that a 12v battery won't power household appliances because they are designed to run off of the 100v house circuit. Where should I start?
Welcome to PF, Jagman.
You need an inverter, not a converter. Most automotive supply places can set you up with one. They're a bit pricey, but not too bad if you really need one. Only problem is, the biggest one that Canadian Tire sells is 400 watts. It costs $60. I don't know about other suppliers. RV dealers might have something bigger.
In addition to what Danger said.
Most electronic equipment is not real happy with plain inverters.
You are going to want a Sine Wave or Modified Sine Wave inverter.
The average computer or TV might run 30 minutes to an hour on a large deep cycle battery like they sell for boats in the auto supply store.
The "Deep Cycle" part is important if you want the battery to last a while.
You can get inverters up to 2000 Watts, but to run one for any length of time is going to be a major investment in batteries.
http://www.invertersrus.com/
Check these people out, i have bought 1- 5000Watt, and 2- 2500Watt, inverters from them and have been pleased with all units. At the time, they came with cables(4 on the 5K) and were, sales tax and freight free. (i have had no problems with any units)
Before finding this source, i bought a Vector 3000Watt, and a couple of smaller units, they required sales tax and cables
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
