Horizontal and vertical independance
The discussion centers on the differences between projectile motion and pendulum motion in physics. In projectile motion, the horizontal and vertical components are independent, with gravity only affecting the vertical component. In contrast, pendulum motion involves both horizontal and vertical components that are interdependent due to the circular constraint of the pendulum's swing. The conversation highlights the importance of understanding how energy changes in different motion scenarios and suggests that mathematical frameworks like Lagrangians can clarify these relationships. The key takeaway is that while projectile motion allows for separation of components, pendulum motion does not due to its rotational nature.
phlegmy
hey guys,
i studied "applied maths" in "high school" [the irish version!]
we studied projectile motion and velocity vectors etc,
we worked on the premise that gravity affects only the verticle velocity of the projectile
so that:
for a projectile given an initial velcoity both horizontally and vertically (i and j)
the horizontal component would remain unchanged [obviously diregarding any frictional forces], while the verticle component is subject to change due to gravity.
fine.
now i turn my mind to a pendulum, free to swing both left and right, as well as front to back, and i figure: the left-right motion can be treated seperatly to the front-back motion, each discribing, in that direction,the motion it would otherwise assume were the other direction neglected. and then:
i think surely not!
> i imagine that, in the left-right motion the pendulum is swinging not as a pendulum but rather in full circuls, and very fast. i then reason (rightly or wrongly) that were i to nudge the pendulum in the forward-backward direction that it would not oscillate forwards and backwards but rather be restored to its inital position. similar to the way that a bullet which spins along the axis of its trajectory will not become unstable.
assuming that what i have said is correct [open to correction!] i am left with a conumdrum:
when is it acceptable to split an objects motion into x,y or x,y,z and why
is it something to do with rotation?
or am i missing something else more fundamental.
thanks for your thoughts!
james
Hi James,
The difference between your two examples, the projectile and the pendulum, is crucial. In the projectile case only changes in the vertical direction change the energy of the projectile. In the case of the pendulum, movement in either direction will change the energy, because it is constrained to move in a circle. So x and y and not independent in the second case, but are so in the first.
You can see this mathematically if you write the Lagrangians of the two systems.
thats mentz, although you replied in less than an hour and its taken me 10 days to read it!
i see your point.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
