Simple Energy conservation, PE = KE + PE
A block mass M slides down a frictionless circle and flies off at an angle Theta, which is determined using energy conservation principles. The relationship between potential energy (PE) and kinetic energy (KE) is established, leading to the equation PE(top) = KE(point) + PE(point). The normal force becomes zero at the point of departure, allowing for the application of centripetal force equations. The calculations suggest that the angle Theta can be derived from the conditions where the normal force is zero, leading to the conclusion that the angle is approximately 48 degrees. The discussion emphasizes the importance of correctly applying energy equations and understanding the forces acting on the block.
Scrum
A block mass M slides down the side of a frictionless circle Radius R. At an angle Theta the mass M flies off the circle, what is the angle?
PE(top) = KE(point it flies off) + PE(at that point)
Arad = V^2 / R
Sum Of Forces = Mass * Acceleration
Okay I actually did this one before and I was trying to do it again but somehow I don't seem to be able to get it. The answer was Inverse Cosine of 1/1.5 or 48 degrees.
The problem was done with energy equations
I set 0 PE to be the middle of the circle so
mgR = .5 mv^2 + mg(Rcos(theta))
mass cancels
gR = .5v^2 + gRcos(theta)
I think I'm going wrong here but I said the only force acting on the block is weight or mg, because at the point is leaves the normal force goes to 0.
so sum forces = mass * acceleration
mg = ma
mass cancels
g = a
then v^2 / R = a , so gR = V^2
then plugging that in
gR = .5gR + gR cos(theta)
gR cancels
1 = .5 + cos(theta)
and I end up with 60 degrees so I think I missed out a number somewhere but I don't know where.
It'll leave the surface of the sphere when the normal reaction N becomes zero.
If \theta is the angle made with the upward vertical with the radius at the position of the particle, then the centripetal force is given by,
mv^2/r = mgcos\theta - N, which will give you mv^2 when N=0.
Also, KE = change in PE from top position, which gives,
mv^2/2 = mg(...) [you find it, in terms of r and \theta, using geometry].
From this, you'll get \theta.
