Time Dilation and aging Problem
The discussion revolves around a physics homework problem involving time dilation and aging during a flight across the United States. The user is trying to calculate the time difference experienced due to relativistic effects while flying at 250 m/s. They reference the time dilation equation and express confusion over their calculations, which yield a different result than the solution manual. Additionally, there is a request for help in locating the solution manual for mastering physics. The user seeks clarification on their approach and calculations to understand the correct answer of 1.39×10−8 seconds.
funkym0nkey
You fly 5000 km across the United States on an airliner at 250 m/s. You return two days later traveling at the same speed. How much less have you aged more then your friends at home.
I think the time dilation equation is used:
delta_t= delta_t'/ sqrt(1-beta^2) where beta= v/c
I have the solution from the solution manual but i'd like to know how they got to the answer, 1.39×10−8 s.
to find the delta t is the equation delta_t=delta_x/v used?
the beta is (250m/s)/(3.0*10^(8) m/s )
i keep getting 1.7 *10^-5 although the solution manual says this is incorrect.
Any advice is appreciated!
hi !
I've been so desperate to find the solution manual for mastering physics..!
Can you please tell me where you got it/?
or if it is possible, I would really really appreciate it if you could can it to my email, which is
guswns3310@hotmail.com
Thank you very much
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
