Finding the currents of four resistors in a circuit.
The discussion revolves around finding the currents through four resistors in a circuit powered by a 12V battery. The resistances are given as R1 = 15.0 ohms, R2 = 45.0 ohms, R3 = 25.0 ohms, and R4 = 25.0 ohms. Participants are exploring the relationships between the currents and the application of circuit laws.
  • Mixed
  • Participants discuss reducing the circuit to find equivalent resistance and express confusion about determining individual currents due to the series and parallel arrangements of resistors. Some suggest using Kirchhoff's laws to set up equations relating the currents.
Several participants have shared their attempts at forming equations based on Kirchhoff's laws, with some expressing uncertainty about the number of equations and unknowns. Others have provided guidance on simplifying the problem by recognizing relationships between currents. The discussion is ongoing, with participants actively seeking clarification and assistance.
There is mention of confusion regarding voltage drops and the need for a clear understanding of circuit topology. Some participants have noted difficulties with algebraic manipulation and the use of matrices for solving the equations.
vertabatt
[tex]\epsilon[/tex]batt = 12V
Find the following currents.
The current I1 through the resistor of resistance R1 = 15.0 ohms.
The current I2 through the resistor of resistance R2 = 45.0 ohms.
The current I3 through the resistor of resistance R3 = 25.0 ohms.
The current I4 through the resistor of resistance R4 = 25.0 ohms.
I = V/R
First I reduced the circuit to find the equivalent resistance of all resistors R = 56.5 ohms. From this I was able to determine that the current from the equivalent resistor is 12/56.5 = .212 A.
I am really confused as to how to solve for the currents through each element since I don't know the ∆V of each and some are in series while others are in parallel.
Any help is appreciated!
vertabatt said:
I am really confused as to how to solve for the currents through each element since I don't know the ∆V...
You don't need it. Take a look at "[URL circuit laws[/URL]. Maybe it will help.
I = V/R
Do you know Kirchhoff's laws?
If we consider I2 flowing upwards while I3 and I4 flow downwards, we have the following system
I3 = I4 (R3 and R4 are in series)
I2 = I1 + I3 (The current I2 distributes between the two branches)
and then the voltage drop between the upper node and the lower one is the same along the three branches
e - I2 R2 = I1 R1 = I3(R3+R4)
you have a linear system of four equations that gives you the four currents.
I completely follow you, until I get here:
Why does the voltage drop on the right have to the the same as the voltage drop on the right?
Is it because the wires are at a junction at the top (and therefore must be at the same voltage) and there is a junction at the bottom (so these must also be at the same voltage)?
That would make sense since the ∆V would have to be the same...
Also, what is the best way to solve the group of equations? I tried using a matrix, but I did not get the correct answer. It has been a looong time since I have attempted one, so it is possible I made an error.
First off, give a direction to all of your currents in that circuit, and use Kirchhoff's Loop and Junction Laws:
At a junction: [tex]\Sigma I_{in}=\Sigma I_{out}[/tex]
Around any closed loop: [tex]\Sigma \Delta V = 0[/tex]
You'll have three equations, and three unknowns. It may be easier to use a matrix, but if you don't know how to use one, do it algebraically.
I am still stuck on this problem. I came up with the equations:
I3 = I4
I2 = I1 + I3
(e-I2R2) - (I1R1) = 0
(e-I2R2) - (I3R3 + I4R4) = 0
I'm not sure why you say I have three equations and three unknowns... isn't it four? Or maybe you eliminated one since I3 = I4. Honestly, my algebra skills must be terrible, because I cannot seem to solve this.
I have spent way too much time on this, and I am pretty close to conceding... giving it a few more go's. Someone please let me know if you find something wrong with my equations or method.
Thanks.
That's right, it's only three because I3=I4, so you don't need to worry about an I4 term. Replace all I4's with I3's to make your problem easier.
Other than that, everything else looks good. Start by solving for one variable in one equation, and sticking it into another.
Because it's a voltage drop. The voltage difference depends only on the initial and end points and not on the path followed to go from one point to the other.
If we call Va to voltage of the top node and Vb the voltage of the bottom one, we have for the left branch
Va - Vb = I1 R1
for the right one
Va - Vb = I3 R3 + I4 R4 = I3(R3 + R4)
and for the central one, taking into account the dc source
Va - Vb = e - I2 R2
It is also possible to simplify by replacing R3 and R4 by R5=50 ohm, to make the equations look nicer.
Thanks for your help everyone... I was able to solve this using my three equations. It was just a matter of plugging them into each other and avoiding stupid mistakes (which I am prone to).
I1 = .163
I2 = .212
I3 = I4 = .0490
Here's my method to do the same problem:
Combine all resistors into one equivalent resistor across the battery.
When that can be done, I wouldn't write a set of simultaneous equations.
Let R34 = R3+R4 = 25+25 = 50 ohms
Let R123 = R1 parallel R34 = (15)(50)/(15+50) = 11.54 ohms
Let R equivalent = R134+R2 = 11.43+45 = 56.54 ohms
battery current = E / R equivalent :
IE = 12 V / 56.54 ohm = 0.212A
(That's what you called I2)
voltage across R2 given by ohm's law:
VR2 = IE R2 = (0.212A)(45 ohm) = 9.55 V
voltage across R1 equals battery minus voltage across R2 :
VR1 = E - VR2 = 12 V - 9.55 V = 2.44 V
current through R1 given by ohm's law:
IR1 = VR1 / R1 = 2.44 V / 15 ohm = 0.163 A
(That's what you called I1)
Current through R3 and R4 = battery current minus current through R1 :
IE - IR1 = 0.212 A - 0.163 A = 0.049 A
(That's what you called I3)
You can easily solve this with circuit reduction, if you think of it like this:
http://img147.imageshack.us/img147/6876/circuitxs1.jpg
It's pretty straight forward, 3+4 series, 1+34 parallel, 134+2 series
(Sorry the image is crappy but you still get the general idea.)
I have heard it called a principle of circuit topology -- you can visualize a circuit as being bent, twisted, flipped over, mirror imaged, etc., if it helps a person to see it better in their imagination -- as long as you don't add or remove any connections. After doing about a dozen problems a person will no longer find it necessary.
I've never heard it called anything, but yeah after a while you just start to automatically re-arrange the circuit in your mind so that it makes more sense.
There is another, systematic way of analyzing this kind of problems:
We consider each loop separately and label a current that flows around the loop (let's say, counterclockwise). In this case we have two loops: let I1 and I2 be the currents. We construct a vector with these currents
[tex]\mathbf{I}=\left(\begin{array}{c}I_1\\I_2\end{array}\right)[/tex]​
Now, we build a resistance matrix n x n, (being n the number of loops, in this case 2 x 2). The diagonal elements R_ii are the sum of resistances along each loop. The non-diagonal term R_ij is the resistance common to loops i and j, positive if both currents flow in the same direction, negative if they go in opposite directions. In our case
[tex]\mathsf{R}=\left(\begin{array}{cc}R_1+R_2 & -R_2\\-R_2 & R_2 + R_3 + R_4\end{array}\right)[/tex]​
Finally, we construct another vector with the emfs along each loop. Positive if we enter at them through the cathode, negative if we enter through the anode. In our case
[tex]\mathbf{V}=\left(\begin{array}{c}\mathcal{E}\\-\mathcal{E}\end{array}\right)[/tex]​
We obtain the currents solving the matricial equation
[tex]\mathsf{R}\cdot\mathbf{I}= \mathbf{V}[/tex]
[tex]\left(\begin{array}{cc}R_1+R_2 & -R_2\\-R_2 & R_2 + R_3 + R_4\end{array}\right)\cdot \left(\begin{array}{c}I_1\\I_2\end{array}\right)=\left(\begin{array}{c}\mathcal{E}\\-\mathcal{E}\end{array}\right)[/tex]​
The solution of this equation (inverting R) gives I1 and I2. To obtain the current flowing through each resistance you add the currents of the adjacent loops (with their sign), i.e.
[tex]I(R_1)=I_1\qquad I(R_2)=I_1-I_2\qquad I(R_3)=I(R_4)=-I_2[/tex]​
  • · Replies 18 ·
  • · Replies 42 ·
  • · Replies 31 ·
