Linear Mass Density of current and wires
The discussion revolves around determining the current needed for an upper wire to "float" and form an equilateral triangle with two lower wires, which are fixed and 4.0 cm apart. A repulsive force exists between the wires due to their opposite currents, as explained by Ampere's law and the Bio-Savart Law. The challenge lies in balancing the gravitational force acting on the upper wire with the magnetic repulsion from the lower wires. The participant seeks guidance on how to approach the problem, emphasizing the role of gravity in preventing the upper wire from floating. Understanding the forces involved is crucial to solving the problem effectively.
splac6996
[/B]
The figure is a cross section through three long wires with linear mass density 43.0. They each carry equal currents in the directions shown. The lower two wires are 4.0 cm apart and are attached to a table.
What current will allow the upper wire to "float" so as to form an equilateral triangle with the lower wires?
I am not sure where to start could someone give me a hint at what to do?
Hint: A Repulsive force exists between straight current-carrying conductors carrying currents in opposite directions. By Ampere's law, each conductor generates a magnetic field around it and the forces acting on them are basically the forces of interaction between the magnetic fields. Any standard textbook should explain this phenomenon. Look up the Bio-Savart Law or try this link:
hyper-text-transfer-protocol://world-wide-web.physics.upenn.edu/~uglabs/lab_manual/force_between_conductors.pdf
(I'm not allowed to post URLs yet, so just copy-paste the above link in the address bar and rewrite the beginning of the link)
I'm thinking that the only reason why the upper conductor won't float is because of gravity. This means that you probably have to assume that the lower conductors are fixed, otherwise they'd fall too.
