Thread Closed
RIemann-Weyl formula and application
Share Thread Thread Tools
Apr22-08, 02:14 PM   #1
given a real function 'f' so the Fourier transform of f(x) exists and assuming Riemann Hypothesis is true so all the non-trivial zeros of Riemann Zeta are of the form 1/2+it then the Riemann-Weyl formula
[tex] \sum _{t} f(t) = f(i/2)+f(-i/2)+2g(0)\pi- (2\pi)^{-1} \int_{-\infty}^{\infty}dr f(r) \frac{ \Gamma '(1/4+ir/2) }{\Gamma (1/4+ir/2)}+ \sum _{n=1}^{\infty} \Lambda (n) (n)^ {-1/2}g(lon) [/tex]
the first sum run over the non-trivial zeros, my question is if all the zeros are 1/2+it with 't' real number , the only condition for Riemann-Weyl formula to converge is that the Fourier transform of f(x) , which can be a function or a distribution must exists ? , under what conditions can be apply Riemann-Weyl summation formula? , if f(x) is a function g(u) is its Fourier transform
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Apr22-08, 10:03 PM   #2
Lets clarify this. The question is confusing. Please use more simple sentences if you can.
Apr23-08, 04:01 AM   #3
Sorry Ramsey , my question was
I have given a formula (Riemann Weyl formula) that relates a sum over the imaginary part of the zeros of Riemann zeta that are in the form 1/2+it
assuming Riemann Hypothesis is true so all the 't' are real, i think that the formula is correct in case the Fourier transform of f(x) exists but i am not sure.
for example if i wan to obtain the sum of [tex] e^{-t^{2}} [/tex] where 't' runs over the imaginary part of all Zeta zeros in the form [tex] \zeta (1/2+it)=0 [/tex] , assuming RH is real could we use the Riemann-Weyl formula ? that was all thanks.
Thread Closed
Thread Tools
Similar Threads for: RIemann-Weyl formula and application
Thread Forum Replies
Weyl Tensor Differential Geometry 18
Weyl tensor Differential Geometry 3
Help with work formula - medical application General Physics 2
