Thread Closed
Does a photon curve space-time, i.e., produce a gravitational field?
Share Thread Thread Tools
May3-08, 02:12 PM   #1
Does a photon curve space-time, i.e., produce a gravitational field? Is the degree of curvature a function of its energy?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
May3-08, 06:04 PM   #2
no. a photon exhibits no locality.
May3-08, 06:06 PM   #3
dst
Quote by jnorman View Post
How are you reading this?
May4-08, 11:38 AM   #4
Yo jnorman! How's it going?
That a photon's position cannot be determined with infinite precision to without leaving its energy totally unknown does not dictate that a photon can't generate a gravitational field. I don't see why they'd be mutually exclusive. One can always give a region of space in which the particle is contained within and as such the energy will be between certain but finite limits. Since a photon has energy it also has active gravitational mass and therefore can generate a gravitational field.
Pete
May4-08, 03:51 PM   #5
hi pmb - i think we have had this discussion before, eh? once a single photon is emitted, it is essentially everywhere in the universe - ie, it displays no locality (ie, its position cannot be defined with ANY precision). since it has no defined position, it, ergo, cannot exhibit any local effect on gravitational field. as i recall, a light beam can, however, generate observable field effects. as always, feel free to correct me...
May4-08, 05:42 PM   #6
Please explain why a photon generates no observable gravitational field effect while a light beam can. Isn't a light beam just a group of more than one photon? Are you specifically referring to a laser beam?
If we place a laser at one end of a sealed tube and a target at the opposite end of the tube and all the photons from the laser arrive at the target within the expected time, then does that not imply a high probablity of the photons being within the tube during the journey from the laser to the target and imply some sort of locality? I find the quick tour of the universe by the photons between the emmiter and the target hard to visualise, especially if we limit the photons to the speed of light :P As I understand it the locality of a photon has a probabilty distribution that puts a high probability on the position ofa photon being in a certain area and a very small probabilty of it being almost anywhere else. I think it is a bit like the position of an electron that belongs to an atom. There is a small possibility of the electron being almost anywhere in the universe, but a much higher probability of the electron being somewhere near the atom it "belongs" to. With this analogy we could say that an electron has no locality and therefore no influence on the gravitational field which I think you will agree is nonsense.
May5-08, 11:30 AM   #7
Recognitions:
Gold Membership Gold Member
I think we can all agree that it is not possible (at present) for us to measure the gravitational field of a photon. So, all of this discussion must be somewhat speculative. The correct answer to this question is not known with any high degree of certainty, is it?
I am pretty sure the photon does not have a gravitational field. I say this because a photon has no mass other than relativistic mass. If relativistic mass is a source of gravity, apparent paradoxes arise. If these paradoxes cannot be resolved, they serve as proof that relativistic mass cannot be a source of gravity, and gravity only proceeds from rest mass. Since a photon has no rest mass, it has no gravity. (That's my speculation.)
May5-08, 02:31 PM   #8
Since photons respond to gravity. as we can see from gravitational red/blue shifting as well as from gravitational lensing, there is no reason not to believe the photons themselves have a gravitational field.
And, Lurch, a photon may not have an invariant mass, but it does have an invariant energy, i.e., hf, so I don't see what paraxoes would arise from considering hf as equivalent to mass-energy.
May5-08, 02:42 PM   #9
As Einstein Said "The mass tells the space how to curve, and the space(-time curvature) tells the mass how to move", which may translate to "every thing that has mass create a curvature in spacetime and everything that follows the curved spacetime (i.e. responds to gravity) has mass".
Since, the photons respond to gravity, they have mass (let it be reletivistic) and hence should curve spacetime.
May5-08, 09:08 PM   #10
Quote by redtree View Post
Well, i'm an ether fan so I have to say no on this. lol don't quote me
May5-08, 11:31 PM   #11
Spatial curvature is described by 10 numbers; roughtly how time curves into space, space into space, and finally time into time (10 = four spacetime compontents taken two at a time, disregarding order taken). An electromagnetic wave is unique in that, unlike massive matter, all of it's energy is it's momentum. It will curve spacetime differently than massive objects. But you asked about photons. Photons propagate as waves (but so do the massive objects). So now we have to mix quantum mechanics with general relativity. Good luck with that, as no one has measured the effects of a single photon, or even a flock of them, on spacetime curvature. But in theory one can treat a photon as a propagating wave with a bandwidth and spatial extent having a well defined energy at each point in spacetme. If you want to know how such an electromagnetic field would bend spacetime you need one of the smart guys around here, because I have very little clue, sorry.
May5-08, 11:59 PM   #12
Quote by LURCH View Post
Place equal amounts of matter and anitmatter in a box on a scale. It's a very good box; it's very reflective, and light doesn't get in or out. Allow all the stuff to annihilate to photons. Does the box change weight?
May6-08, 07:35 AM   #13
Recognitions:
http://www.physicsforums.com/showthread.php?t=154391
In general relativity, gravity is coupled to energy density and momentum flow, not only mass like in newtonian gravity. On this basis, an electromagnetic wave (general relativity does not consider light in terms of photons) will exert its own gravity, though extremely weak and not currently measurable. Gravity exerted by massive bodies is much higher because of their huge energy content (see the c squared term in the Einstein formula).
Quote by mitesh9 View Post
This quote was not by Einstein but by John Wheeler, and he said "matter", as a generic term, not "mass" (see C. W. Misner, K. Thorne, J. Wheeler, "Gravitation", W. H. Freeman (1973), page 5). Also it is just a pedagogical way to summarize the meaning of general relativity, one must always refer to the actual formulas to determine what the theory precisely says.
May6-08, 07:37 AM   #14
Quote by Phrak View Post
Good one!!!
May6-08, 07:58 AM   #15
To be precise there is no quantum theory of gravity (or relativistic quantum mechanics) so we're really all taking an educated guess. However I see no reason to assert that a photon is everywhere in the universe. Quantum mechanics certainly makes no such assertion. All that can be said is that for each quantum state of any particle there is an associated wave function. The physical interpretation of that wave function is that the magnitude squared of the function represents the probability density of finding the particle in a particular region. Only when the exact value of the momentum is determined will the probability density be uniform and thus the chances of finding it anywhere in the universe will be zero. However that comes from non-relativistic quantum mechanics. Relativity restricts the speed of a particle to less than the speed of light and therefore the probability density can never be uniform. And even this interpretation of pronability refers only to essembles of identical experiments, not to individual experiments. There is no restriction on the limits of accuracy placed on each single measurement.
Best wishes
Pete
May6-08, 08:00 AM   #16
Quote by xantox View Post
Wheeler made such statements in various places and using different terms each time. In Exploring Black Holes he phrased it using the term mass rather than matter. Due to the way the authors definined mass in that book I protested but Wheeler was adament about it.
Pete
May6-08, 08:13 AM   #17
We know that light pulled in by gravity so we know that at least some weight will remain if not all.
Or as one of my physics professors said, weigh a flashlight, turn it on till the batteries die then weigh it again now that all the light is out of it =)
Thread Closed
Thread Tools
Similar Threads for: Does a photon curve space-time, i.e., produce a gravitational field?
Thread Forum Replies
Space time curve Special & General Relativity 2
since time slows down in a strong gravitational field, does time stop in a black hole Special & General Relativity 12
???? Earth's Gravitational Field Effect on space shuttles Introductory Physics Homework 6
Does Magnetism Curve Space and Time Special & General Relativity 14
How do you calculate time dilation in a gravitational field Special & General Relativity 19
