Thread Closed
Ethanol (=alcohol) added to gasoline
Share Thread Thread Tools
May10-08, 10:55 AM   #1
1. Incredibly it appears that in the United States gasoline may have ethanol in it as an additive. Up to 5% can be ethanol in the fuel sold there. Does anyone know if this is accurate?
2. How do I purify ethanol (=alcohol) to 99%?
3. Where do I buy 99.9% pure ethanol?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
May10-08, 12:37 PM   #2
Recognitions:
Homework Helper Homework Help
Gasoline is a mixture of all sorts of hydrocarbons typically around 5-8 C long so a bit of ethanol isn't going to make a lot of difference.
You can purify ethanol by simple distillation although it's hard to get above 90% because ethanol readily absorbs water from the air.
You can buy high purity ethanol from the normal lab supply companies, sigma-aldritch etc but it isn't going to be high purity for long once you open the bottle.
May11-08, 09:47 AM   #3
Recognitions:
Gold Membership Gold Member
There's nothing particularly shocking about oil companies adding ethanol to the fuel you buy. More curiously, incentive/legislation is made such that bio-ethanol is added to pump fuel in many countries, which is understandably controversial.
May12-08, 09:39 AM   #4
Recognitions:
Quote by Ulysees View Post
In modern days, Ethanol is being added to gasoline to raise its effective Octane number. It is basically a replacement for MTBE and tetra-ethyl lead. tetra-ethyl lead was originally used for raising a fuel's resistance to spark knock, followed by MTBE which didn't contain lead, but turns out to be carcinogenic. Basically, Ethanol is one of the only additives that can be used with gasoline that is easy to manufacture and does not have heavily toxic or carcinogenic effects like tetra-ethyl lead or MTBE. Still, I think that many toxic properties of gasoline additives such as MTBE are blown far out of proportion.
http://en.wikipedia.org/wiki/Tetra-ethyl_lead
http://en.wikipedia.org/wiki/MTBE
May12-08, 09:57 AM   #5
Your local liquor store has pure grain alcohol which is 98% alcohol.
On the other note, with the United States requiring 10% ethanol in gasoline, it is setting up the infrastructure to switch to E85 in the distant future.
May13-08, 11:13 AM   #6
Recognitions:
Quote by sirzerp View Post
That would be a special liquor store. Alcohol forms an azeotrope at lower concentrations, so stuff above 96% is going to be hard to find. The usual methods for getting higher concentrations are discussed in fuel distillation sites.
http://running_on_alcohol.tripod.com/
May13-08, 11:29 AM   #7
Recognitions:
Not in Ohio you won't. Kentucky on the other hand....
May20-08, 06:15 AM   #8
Sorry, wrong thread, ignore this.
Thread Closed
Thread Tools
Similar Threads for: Ethanol (=alcohol) added to gasoline
Thread Forum Replies
Making Wood Alcohol/Methyl Alcohol Chemistry 9
Ethanol for drinking, Ethanol for fuel. Chemistry 7
Added surds General Math 7
gasoline engine modification - ethanol fuel General Engineering 1
why is ethanol the only drinkable alcohol? Chemistry 9
