| Thread Closed |
[SOLVED] acceleration of mass on table |
Share Thread |
| May23-08, 09:49 PM | #1 |
http://www.badongo.com/pic/3633497 3. The attempt at a solution The resultant force of the two hanging mases is 19.6 N. This means that just after the masses are released, the friction is 0.3*mg = 4.41 N, so that the total resultant force is 15.2 N. The acceleration is then 15.2/1.5 = 10.1 m/s^2 Why am I wrong? |
| May23-08, 10:25 PM | #2 |
First of all, The coefficient of friction you have is for static friction.
Secondly, you must account for the entire system's mass since they are all accelerating. |
| May23-08, 10:35 PM | #3 |
Recognitions:
You got an answer larger than 9.8m/s^2. That should be sending up alarms. No matter how heavy m3 is it's maximum acceleration down is 9.8m/s^2. Now try and do the problem right. There is a tension T1 and T2 in each of the two strings. You have to do a force balance for each mass and then set all of the accelerations equal.
| May23-08, 10:50 PM | #4 |
I solved it in the same way, replacing the static coefficient with the dynamic, and replacing m2 with (m1+2+3). 1.9m/s^2. I don't know if my method is right, but it gave me the correct answer.
| May23-08, 11:02 PM | #5 |
Recognitions:
| Thread Closed |
Similar discussions for: [SOLVED] acceleration of mass on table
| [SOLVED] Two blocks - one on a table and one hanging - acceleration with friction | Introductory Physics Homework | 28 | ||
| A spool of mass M sits upright on a table... | Introductory Physics Homework | 13 | ||
| Acceleration of hollow sphere rolling down table. | Introductory Physics Homework | 3 | ||
| Pt. Mass and Spring rotating on table | Introductory Physics Homework | 1 | ||
| probability mass function of a hash table? | Introductory Physics Homework | 1 | ||
