What is the equation for time dilation in gravitational fields?
Wizardsblade
Hey I have done a few google searches, and I do not have a relativity book to let me know what the equation for time dilation is. So I tried to figure it out on my own and come up with this for instantanious time dilation...
Td = cos^{-1}(\frac{Ag' + Am'}{1-Ag'*Am'/c^2)}​
Where Ag' is the first dirivitive of the acceleration of gravity and Am' is the instionious velocity of the object.
If this is wrong can anyone help me find the actual equation for time dilation?
I don't know what I was thinking the equation I ment was...
Td = sqrt[1-(\frac{Ag' + Am')^2}{(1-Ag'*Am'/c^2)^2]}​
I think you need to specify clearly what time-dilation you are talking about. Usually we talk about two clocks running at different rates as time dilation.
Your formula reminds me of the relativistic velocity addition formula.
Very good I used the velocity addition formula to derive the amount of time dilation someone will see when looking at another object. I should probably add that Ag' is the difference in your acceleration due to gravity and their's. Just as Am' is really just your difference in velocity.
I'm still not clear. You need to explicitly show the form of Am' and Ag'.
The dimensions (units) don't seem to match up in any case.
Special relativity says that an observer moving at speed v wrt to a clock will measure that clock slowed down by a factor \gamma = \sqrt{1 - \frac{v^2}{c^2}} and this effect depends only on the relative velocity.
Gravitational time dilation is a separate effect. The dilation is approximately
\sqrt{1 - \frac{2\phi}{rc^2}} where \phi is the gravitational potential.
Well it looks like I am close. Am's = v, and Ag' = 2θ/r. How does one calculate total time dilation for an object in a gravitational field and moving?
From what I can gather, it depends on whether the massive object is being accelerated transversely or not.
If a massive object is infalling radially (ex: the massive object's direction vector is equal to the direction vector formed by the gravitational time dilation gradient), then it seems that the kinematic time dilation is simply due to gravitational time dilation. If they were not equal in this instance, then the infalling massive object's velocity would become practically c at a distance of 1.5 Rs, and not Rs.
If a massive object is orbiting (ex: the massive object's direction vector is perpendicular to the direction vector formed by the gravitational time dilation gradient), then kinematic time dilation is in addition to gravitational time dilation. My reasoning behind this comes from the relativistic precession of orbit, and how two-thirds of it results from the difference in the rate of time due to Newtonian vs. Einsteinian "potential" (gravitational time dilation), and one-third results from the difference in the rate of time due Newtonian vs. Einsteinian kinematics (kinematic time dilation).
This is all considering that an approximate formula for relativistic precession of orbit (measured in orbits per orbit) is:
r is semi-major axis of orbit
e is eccentricity of orbit
\delta = \frac{3GM}{rc^2 (1 - e^2)}
(multiply by 2\pi to get radians per orbit)
and that:
\sqrt{1 - \frac{GM}{rc^2} } = \sqrt{1 - \frac{v^2}{c^2} }
Use general relativity. Unfortunately it's not trivial. I suppose you could choose two freely falling frames at different points on the same geodesic
Shalayka is using GR.
M
Mentz is being very generous. I might *look* like I'm using GR, but what I'm really doing is using a whole bunch of half-a**ed logic that I've pieced together over the last year during the five minutes a day that I've got to study GR. :)
I personally couldn't verify if my reasoning is correct, but so far no one's pointed out a major flaw in it, and boy oh boy -- when you're wrong regarding physics, EVERYONE let's you know (in a not so nice way, generally).
Thanks for the vote of confidence Mentz. It's pretty much the first I've ever gotten.
and that:
Hi Shalayka,
a derivation given in this post https://www.physicsforums.com/showpost.php?p=1526798&postcount=25 that simply assumes the proper time of an orbiting clock (circular orbit) is the classic Kepler orbital period multiplied by the gravitational time dilation and the kinematic time dilation due to the orbiting clocks orbital velocity, agrees with a derivation obtained by Pervect using a different method. The derivations seem to agree with your conclusions for the time dilation experienced by an orbiting body.
Hi shalayka,
whenever I see this
I think Schwarzschild metric and GR. But I suppose that expression can be got outside GR.
Five minutes a day is not a lot - try to get it up to ten ...
M
Since \sqrt{\frac{GM}{r}} and v are both velocities if you want to find the total time dilation for an object in a gravitational field with a velocity would you need to add the two velocities using the relatavistic velocity addition like this?
\sqrt{1 - \frac{\frac{\frac{GM}{r}+V}{1-\frac{GMV}{rc^2}}}{c^2} }
Assuming no gravitational forces on the viewer of course.
My crack at this would be:
- \vec{A} is the unit 3-vector pointing from the center of the orbiting body to the centre of the gravitating body
- \vec{B} is the unit 3-vector describing the direction of the orbiting body's travel
- \phi is the angle between \vec{A} and \vec{B}: \phi = \arccos(\vec{A}\cdot\vec{B}) = \arccos({A}_x{B}_x + {A}_y{B}_y + {A}_z{B}_z)
- \omega is the time dilation factor: 2 + (1 - \cos\phi), or if you like: 3 - \vec{A}\cdot\vec{B}
Note: This calculation does NOT take into consideration the scenario where the body is moving directly away from the gravitating body (ex: \cos\phi < 0). I don't think that counts as freefall, so I'm avoiding it.
\sqrt{1 - \frac{\omega GM}{rc^2}}
Where \vec{A} = \vec{B}, \vec{A}\cdot\vec{B} = 1, \phi = 0, \omega = 2, the body is in freefall directly toward the gravitating body.
Where \vec{A}\cdot\vec{B} = 0, \phi = \frac{\pi}{2}, \omega = 3, the body is in freefall transversely (circular orbit).
I've only had one cup of coffee yet, so take this calculation very cautiously. :)
