How is the 4-momentum 4-vector defined in relativistic QM?
The 4-momentum 4-vector in relativistic quantum mechanics (QM) is defined similarly to classical relativity, with the metric conventionally being (+---), though Weinberg employs the (-+++) metric in flat general relativity (GR). In quantum field theory (QFT), the 4-momentum is linked to phase change rates in plane wave eigenfunctions, represented as ψ(x) = e^{-iEt/\hbar + ipx/\hbar}. The 4-momentum operator, denoted as P^\mu, appears in the translation operator e^{-iP^\mu a_\mu} and can be derived from the Lagrangian through Noether's theorem, which asserts the existence of conserved quantities due to action invariance under spatial and temporal translations.
  • Understanding of 4-vectors in physics
  • Familiarity with quantum field theory (QFT)
  • Knowledge of Noether's theorem
  • Basic concepts of Lagrangian mechanics
  • Study Weinberg's "Quantum Field Theory" Volume 1, Chapter 2
  • Learn about the implications of the (+---) and (-+++) metrics in relativity
  • Explore the derivation of conserved quantities via Noether's theorem
  • Investigate the role of phase change rates in quantum mechanics
Physicists, students of quantum mechanics, and researchers in quantum field theory seeking to deepen their understanding of the 4-momentum 4-vector and its applications in relativistic contexts.
pmb_phy
I've been wondering about relativistic quantum mechanics. Elsewhere I'm addressing some comments about this branch of physics but I have never studied it. Is the 4-momentum 4-vector defined in the same way in relativsitic QM or is there a difference? I'm wondering if the time component of 4-momentum is defined in the same way in relativistic QM as in classical relativity. Thanks.
Pete
Pete
Yes, generally the metric is (+---), although Weinberg uses (-+++) as in (flat) GR.
In QFT the 4-momentum is typically associated with the phase change rates in the
time and space components corresponding to the plane wave eigenfunctions:
[tex]\psi(x)~=~e^{-iEt/\hbar + ipx/\hbar}[/tex]Regards, Hans
It's defined as the [itex]P^\mu[/itex] that appears in the translation operator [itex]e^{-iP^\mu a_\mu}[/itex], where [itex]a^\mu[/itex] is the translation four-vector. This definition works in both relativistic and non-relativistic QM. (The best place to read about these things is chapter 2 of vol. 1 of Weinberg's QFT book).
In a relativistic quantum field theory, you can also construct the four-momentum operators expliclity from the Lagrangian, as the conserved quantities that Noether's theorem tells us must exist due to the invariance of the action under translations in space and time.
  • · Replies 87 ·
9K
  • · Replies 473 ·
34K
  • · Replies 36 ·
  • · Replies 69 ·
  • · Replies 22 ·
