What is the formula for finding the sum of a Geometric Series?
The discussion centers on finding the sum of a geometric series, specifically using the formula for a finite geometric series. The original poster attempted to calculate the sum using a formula that was unclear due to formatting issues. A clearer representation of the formula is provided, emphasizing the need for proper notation to avoid confusion. The correct formula for the sum of a finite geometric series is shared, which can help in calculating the desired total. Overall, the conversation highlights the importance of clarity in mathematical expressions for accurate problem-solving.
ssjSolidSnake
Hi, I'm having trouble finding the sequence's total sum from a formula concerning Geometric Series.
I've been using a calculator to find and manually input all of the terms into a table in Microsoft Excel and adding them all up at the end. The formula that I was given was \overline{10}\sum\underline{1}4(1/2)^n-1
The total sum that I found was 7.992188, but it was incorrect.
Can anyone help me find the Series Sum?
Mathematics news on Phys.org
Can you express the question a little more precisely? I can't make sense of the overline 10, the underline 1, and where the rest of the formula is supposed to go. Please either use proper TeX code, or don't use it at all and write it out clearly and unambiguously. For example,
10 \sum_{n = 0}^\infty \frac{1}{4} \left( \frac{1}{2} \right)^{n - 1}
or
10 * (sum from n = 0 to infinity)[ (1/4) (1/2)^(n - 1) ]
Sorry about that. I'm not familiar with LaTex so I will attempt to state my problem as clearly as possible. (sum from n=1 to 10) [ 4(1/2)^(n - 1) ]
Thanks for the advice CompuChip
It looks like you have a finite geometric series.
sum(0,N) an = (1-aN+1)/(1-a)
You should be able to do the rest
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
