Solving the Rocket Equation: Confusion with Signs
The discussion revolves around the rocket equation and the confusion regarding the signs used in its derivation. Participants explore the implications of mass loss and momentum conservation in the context of rocket motion, addressing both theoretical and mathematical aspects of the equation.
  • One participant expresses confusion about the signs in the rocket equation derivation, particularly regarding the mass of the rocket and the velocity of the ejected gas.
  • Another participant questions the validity of a step in the derivation, suggesting that the multiplicative inverse of a vector cannot be used and proposes defining a unit vector to clarify the relationship between the vectors involved.
  • Some participants discuss the implications of defining the mass change (dM) as positive or negative and how this affects the conservation of momentum equation.
  • There is a suggestion that the equation v = v_0 + U ln(M/M_0) may be incorrect due to the treatment of dM and its sign in the context of vector versus scalar derivation.
  • One participant points out that the confusion may stem from an earlier misunderstanding of the mass ejection process and its impact on the momentum equation.
Participants do not reach a consensus on the correct treatment of signs in the rocket equation. Multiple competing views on the definitions and implications of mass change and momentum conservation remain unresolved.
There are limitations in the discussion regarding the assumptions made about the mass change (dM) and its sign, as well as the treatment of vector quantities in the derivation.
calculus_jy
recenty i read the rocket equation, derivation of, however i think i have a slight confusion with signs
suppost initially a rocket has
mass= [tex]M[/tex]
velocity= [tex]\overrightarrow{v}[/tex]
then at a time dt later,
mass of rocket= [tex]M-dM[/tex]
velocity of rocket= [tex]\overrightarrow {v} +d\overrightarrow {v}[/tex]
mass of ejacted gas= [tex]dM[/tex]
velocity of gas= [tex]\overrightarrow{u}[/tex]
using conservation of momentum
[tex]\overrightarrow{v}M=(M-dM)(\overrightarrow{v}+d\overrightarrow{v})+\overrightarrow{u}dM[/tex]
[tex](\overrightarrow{u}-\overrightarrow{v})dM+Md\overrightarrow{v}=0[/tex]
but [tex](\overrightarrow{u}-\overrightarrow{v})[/tex]=velocity of gas relative to rocket
let [tex](\overrightarrow{u}-\overrightarrow{v})=\overrightarrow{U}[/tex]which is a constant
[tex]\overrightarrow{U}dM+Md\overrightarrow{v}=0[/tex]
[tex]-\int_{M_0}^{M}\frac{dM}{M}=\frac{1}{\overrightarrow{U}}\int_{\overrightarrow{v}_0}^{\overrightarrow{v}}d\overrightarrow{v}[/tex]
now [tex]-ln\frac{M}{M_0}=\frac{\overrightarrow{v}-\overrightarrow{v_0}}{\overrightarrow{U}}[/tex]
the problem is , when taking the velocity in the direciton rocket is travelling
[tex]\overrightarrow{U}<0[/tex]
[tex]-ln\frac{M}{M_0}>0[/tex]since [tex]\frac{M}{M_0}<1[/tex]
then
[tex]\overrightarrow{v}-\overrightarrow{v_0}<0[/tex] which is impossibe as the rocket is accelerating?
latex problem seems to be fixed now...
i don't see how you get [tex] M- dM<br /> [tex]is is because of [tex]E=mc^2[tex][/tex][/tex][/tex][/tex]
why won't the latex work
I hope this isn't too off topic but
i think you need [/tex] instead of [tex]at the end[/tex]
Good up to this point.
[tex]-\int_{M_0}^{M}\frac{dM}{M}<br /> =\frac{1}{\overrightarrow{U}}<br /> \int_{\overrightarrow{v}_0}^{\overrightarrow{v}}d\overrightarrow{v}[/tex]
This step is not valid. There is no such thing as the multiplicative inverse of a vector. Better is to define a unit vector v-hat directed along the rocket's delta-v vector. From the correct equation, this delta-v vector is directly opposed to the relative exhaust velocity vector. Thus
[tex] \begin{aligned}<br /> d\overrightarrow{v} &= dv \hat{v} \\<br /> \overrightarrow{U} &= U \hat{v} & (U &\equiv \overrightarrow{U}\cdot \hat v)\\<br /> &= -v_e \hat{v} & (v_e&\equiv -U)<br /> \end{aligned}[/tex]
Note that ve is simply the magnitude of the relative velocity vector. With this, the vector differential equation becomes the scalar equation
[tex]-v_edM+Mdv=0[/tex]
from which
[tex]\int_{M_0}^{M}\frac {dM}{M} = \frac 1{v_e}\int_{v_0}^v dv[/tex]
or
[tex]\ln\frac{M}{M_0} = \frac{\Delta v}{v_e}[/tex]
You can use a vector formulation, but you can't divide by a vector like you did.
however is the equation
[tex]v=v_0+\overrightarrow{U}ln\frac{M}{M_0}[/tex] not right?using the notion in the first post
in the step with the integrals, to prevent multiplicative of inverse of vector, simply put [tex]\overrightarrow{U}[/tex]
on the same side of the equation as [tex]\frac{dM}{M}[/tex]
i have been told that its the problem associated with dM such that the mass of rocket after dt is M+dM not M-dM
i don't get why minus can be used in scalar, but cannot be used in vercot derivation?
Your error occurs much earlier than I stated earlier.
Here your dM is the quantity of mass ejected by the spacecraft . With this definition, a positive dM means the spacecraft loses mass. Things would have worked properly if you had used dM as positive meaning the spacecraft gains mass. Then the conservation of momentum equation becomes
[tex]\overrightarrow{v}M=(M+dM)(\overrightarrow{v}+d\overrightarrow{v})-\overrightarrow{u}dM[/tex]
  • · Replies 17 ·
  • · Replies 30 ·
  • · Replies 0 ·
