Can Activated Carbon Powder Fly Using Atmospheric Electric Field?
  • Thread starter Thread starter NERV
The atmospheric electric field exists with a strength of approximately 100 N/m, which is sufficient for a design involving activated carbon powder. The powder can be modeled as conductive spheres with a density of 2.7 g/cm³ and a radius of 1×10⁻⁵ m. To achieve levitation, the powder must be charged to balance the electric force against gravity, requiring a minimum voltage of 10¹⁷ V for flight. A voltage of 2034 V would provide additional lifting force equal to the weight of the powder. Clarification is made that the correct electric field strength is about 100 N/C, not 100 N/m.
NERV
As it is known to all,the atmospheric electric field does exists.In fact,near the ground its strength is about 100N/m.That's enough for my design.
Let's get some activated carbon powder.I think we can regard them as smooth,conductive balls with density(ρ)=2.7g/cm3,r=1×10-5m。If we want a can which has been filled with the powder float in the air by balancing the electric force and gravity,we need to charge the powder so that it can hold an amount of electricity.
Here I gave my calculation. I regarded each of these balls as an isolated conductor,which may lead to error.If anyone has some good ideas,please tell me.
C=4πε0r,FE=qE=UCE=4πε0rUE
if a charged ball can fly:
FE≥mg
∴U≥ρgr2/(3ε0E)
Substitute ρ=2.7×103kg/m3,g=10m/s2,r=1×10-5m,ε0=8.85×10-12(C/V.m),E=100N/m,we get
U≥1017V.
This is amazing.If we use U=2034V,we will get one more lifting force(equals the powder's gravity).
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
