Integration with k as constant
The discussion revolves around the integration of the expression \(\int\frac{dh}{\sqrt{h^{2}-k^{2}}}\), where \(k\) is treated as a constant. Participants are exploring various methods of integration and substitutions related to this integral.
  • Participants discuss different approaches to the integral, including trigonometric substitution and algebraic manipulation. Some express confusion over the steps taken and question the validity of certain transformations.
The conversation is ongoing, with various participants offering suggestions and corrections. There is a recognition of the need for clearer steps and the importance of using trigonometric substitutions, although not all participants agree on the methods being proposed.
Some participants highlight the need to show initial attempts at solving the integral, while others note potential errors in the transformations and substitutions made during the discussion.
ritwik06
PLease HELP ME INTEGRATE THIS>
[tex]\int\frac{dh}{\sqrt{h^{2}-k^{2}}}[/tex]
k is constant
You will have to show some attempt first.
If I take h^2 common from the integral, it will be:
[tex]\int\frac{dh}{h\sqrt{1-\frac{k^{2}}{h^{2}}}}[/tex]
which finally gives:
[tex]\frac{\sqrt{1-\frac{k^{2}}{h^{2}}}}{k^{2}}[/tex]
I don't see how that follows. Your first step is right, next you should use a trigo substitution.
I am redefining the question:
[tex]\int\frac{dx}{\sqrt{x^{2}-a^{2}}}[/tex]
taking x^2 common
[tex]\int\frac{dx}{x\sqrt{1-\frac{a^{2}}{x^{2}}}}[/tex]
let [tex]1-\frac{a^{2}}{x^{2}}=t[/tex]
[tex]\frac{1}{2}\int\frac{dt}{(1-t)(\sqrt{t})}[/tex]
let[tex]\sqrt{t}=j[/tex]
[tex]\int\frac{dj}{1-j^{2}}[/tex]
how shall i proceed
As mentioned before trig substitution is the way to go from the very start.
taking x^2 common
how shall i proceed
I also agree with others, but assuming that you have the last step right:
You should do decomposition and partial fraction ...
You've made it a lot more tedious than it could have been with a simple trigo substitution.
please be more explicit. Actually there is no sign of trigo ratio in the answer :S
taking x^2 common
how shall i proceed
Pretty much every step is wrong. You seem to be consistly forgetting to replace the "dx" or "dt" term.
For example, if you let [tex]1-\frac{a^2}{x^2}=t[/tex] then [tex]\frac{2a^2}{x^3}dx= dt[/tex]. How are you going to substitute for that?
Even if that were correct when you say "let [tex]\sqrt{t}= j[/tex]", you should have [tex]\frac{1}{2\sqrt{t}}dt= dj[/tex].
As everyone has been telling you from the start, use a trig substitution. [tex]sin^2 \theta+ cos^2 \theta= 1[/tex] so [tex]tan^2 \theta+ 1= sec^2 \theta[/tex].
  • · Replies 105 ·
13K
