Why do some salts react with acids while others don't?
  • Thread starter Thread starter nyrychvantel
    Acids
Some salts react with acids while others do not due to their solubility and the relative strength of the acids involved. For instance, CuCO3 can react with H2SO4 despite being insoluble, producing CuSO4, H2O, and CO2. The ability of an acid to displace a weaker acid from a salt is governed by the strength of the acids, as demonstrated by the reaction of CaNO3 with HCl to form CaCl2 and HNO3. Stronger acids, like HCl, can displace weaker acids from their respective salts.
  • Understanding of acid-base reactions
  • Knowledge of solubility principles
  • Familiarity with qualitative analysis techniques
  • Basic concepts of acid strength and displacement reactions
  • Research the solubility rules for salts in aqueous solutions
  • Study the principles of acid strength and its impact on chemical reactions
  • Explore qualitative analysis methods for identifying salts and their reactions
  • Learn about Le Chatelier's principle and its application in displacement reactions
Chemistry students, educators, and professionals interested in acid-base chemistry and qualitative analysis of salts.
nyrychvantel
I am new to the concepts of reaction between of Acids, Bases and Salts.
While learning, I notice that some salts react with acids to form a new salt (and sometimes a new acid is produced), especially in Qualitative Analysis, while some don't even reacts.
I tried to search the internet about it but to no avail, I've no choice but to ask you guys.
Why is it that some salts do not react with acids? Is it because of it's solubility in water or other reasons?
That also contradicts me because [tex]CuCO_3[/tex] + [tex]H_{2}SO_4[/tex] [tex]\longrightarrow[/tex] [tex]CuSO_4[/tex] + [tex]H_2O[/tex] + [tex]CO_2[/tex]
[tex]CuCO_3[/tex] is an insoluble salt, but it is still able to react with acids.
Why do salts even react with acids in the first place, that doesn't make sense to me.
For example if [tex]CaNO_{3}[/tex] reacts with [tex]HCl[/tex] to produce [tex]CaCl_2[/tex]and [tex]HNO_3[/tex], why woundn't the [tex]CaCl_2[/tex] reacts with [tex]HNO_3[/tex] again to form back [tex]CaNO_{3}[/tex] and [tex]HCl[/tex]?
Acids favor the dissolution of salts via the La Chetelier's principle - this is one way.
For your second question consider which is the better acid.
there are many acids, and each one has its own 'strength'. sulphuric acid is a stronger acid than ethanoic acid.
if you have ethanoic acid reaction with NaOH, you will get the salt sodium ethanoate. but if you then add sulphuric acid to this salt, the weaker ethanoic acid will be displaced by the stronger sulphuric acid to give sodium sulphate and ethanoic acid back.
HCl is stronger than HNO3 which is stronger than H2SO4...etc
HCl will be able to displace HNO3 from a nitrate salt, but HNO3 will not be able to displace the stronger HCl from a chloride salt.HCl will displace the weaker carbonic acid from the carbonate as well.
37K
  • · Replies 28 ·
12K
  • · Replies 80 ·
12K
  • · Replies 75 ·
13K
