Bode Diagrams for Transfer Function: (s+2)/(s*(s+10)*(s^2+2s+2))
The discussion focuses on creating Bode diagrams for the transfer function (s+2)/(s*(s+10)*(s^2+2s+2)). Key points include identifying breakpoints at 2, 10, and additional values derived from the polynomial expression. The slope of the asymptotes is determined by the location of breakpoints in the numerator and denominator, with a slope of -1 for the (jw)^-1 term. The conversation highlights the importance of separating magnitude and phase plots, especially in control systems, and suggests using MATLAB's margin command to obtain gain and phase margins.
  • Understanding of Bode diagrams and their significance in control systems.
  • Familiarity with transfer functions and their components, including poles and zeros.
  • Basic knowledge of MATLAB, specifically the margin command for analyzing control systems.
  • Concepts of magnitude and phase plots and their relationship in frequency response analysis.
  • Learn how to identify breakpoints for complex transfer functions in Bode diagrams.
  • Study the process of converting magnitude plots to phase plots in control systems.
  • Explore MATLAB's margin command to analyze gain and phase margins effectively.
  • Investigate the impact of second-order terms on Bode plots and how to approximate them.
Students preparing for control systems exams, engineers working with frequency response analysis, and anyone looking to master Bode diagram techniques in MATLAB.
UnteljentEnginyr
So I have a midterm on Bode Diagrams and Root-Locus on Thursday...and I can not do either. At this point I am only focusing on the Bode diagrams because they are a bit easier and I want to master them now so that I can devote the rest of my time to the Root-Locus.
Say I have the transfer function
In Bode form, this becomes
(jw/2+1)/(10*jw*(jw/10+1)*((jw)^2/2+jw+1))
I am sorry for the difficulty when looking at the function...I have no way of making it look better.
Could someone walk me through a problem like this?
This is what I know:
-The break points will occur and 2, 10, and some other value derived from the polynomial expression.
-The slope of the asymptotes will be plus or mine 1, depending on if the break point is in the denominator(-1) or numerator (+1)...the slope of the first will be -1 because of the (jw)^-1 term.
What I don't know:
-The break point of the polynomial (and imaginary) expression
-How to go from the magnitude plot to the phase plot
-what the intercept at the magnitude axis (y-axis) will be...is it random or is there an actual way to find it.
I have done the bode plot in Matlab...but I can't really make out changes in slope well, nor can I get an accurate Magnitude axis intercept.
I hope this makes sense. And look forward to my questions from Root-Locus.
I'm moving this to homework help where you may get a better viewing.
Sorry I can't help... I blasted controls from my memory shortly after passing the course.
bode is all about approximations.
unless the teacher has explicitly shown you how to do 2nd order terms in class, i wouldn't worry too much --- second order terms are a bit harder to do. in my control systems class, the teacher did a lot with RL and bode, but mainly wanted us to show info on gain and phase margins instead of making pretty pictures!
magnitude and phase plots are realistically separate -- an important fact for control systems where "transport lag" becomes a big factor of the phase, and yet doens't affect magnitude!
but assumeing no lag, sure you can do it. you just need to find the poles and zeros on the plot. again, easy for 1st order terms, but not as easy for second order terms.
in matlab, look at the margin command -- it will give you the gain and phase margin and frequencies!
  • · Replies 16 ·
