Feeling Overwhelmed in the Lab? Advice for Carrying Out Experiments
  • Thread starter Thread starter Boogeyman
    Experiments Lab
Feeling overwhelmed in the lab is common, and preparation is key to building confidence. Engaging with lab TAs and asking questions can clarify confusing procedures, especially when experiments precede lecture coverage. Writing out procedures in personal terms and creating blank data tables can streamline the process and enhance understanding. It's also beneficial to familiarize oneself with upcoming experiments and lab scripts in advance. Ultimately, hands-on experimentation and a proactive approach can significantly improve lab experiences.
Boogeyman
I find that in the lab I feel overwhelmed when doing experiments with the rest of the class. What did you guys do to feel comfortable carrying out experiments? I mean, I'm always unsure of what I'm doing..any tips guys?
You need a good lab partner. And if you wanted to cheat a little, you could always attend the same lab in for another session in advance to prepare yourself. Reading through the lab notes and attempting to answer the questions beforehand (conceptual test qns) would also help.
There are labs when you actually do the experiment way before the lecture notes even cover them. I had 2 of these before, and they were downright confusing. What I did was to ask the lab TAs questions and listen in on questions asked by others. You'll realize that sooner or later the lab TAs might give away a little of the answer or at least a helpful approach to do the experiments.
Being successful in lab depends a lot on your preparation for lab. You should know the basic steps of the procedure ahead of time and only consult the instructions/lab manual for details such as amounts, times, etc. You should also know what to expect as your results, so you can spot errors as they occur and troubleshoot on the fly.
One suggestion for being better prepared, is to write out the procedure in your own words. This can be expecially helpful if your instructions are not too detailed. For example, if your instructions say "prepare a 0.1M solution of HCl," you could write in your notebook, add x mL of 1M HCl to y mL of water instead. That way, you already have the calculation done ahead of time and you don't need to mess around with figuring out the volumes in lab. Even drawing blank data tables for data collection ahead of time can be helpful.
Oh okay I will surely do these things this year. I'm writing the CXC (now CSEC) exams so I have to work extra hard. The only thing is teachers like to tell us which lab we're doing and how to do it when we actually reach in the lab. Which really sucks by the way.
I've found labs difficult thus far. Best thing is to find out what experiment you're going to be doing in advance and then try to get hold of a copy of the lab script for that experiment.
Another thing, my biggest issue, is essentially confidence. Read your script, expect it not to make complete sense, ask for a standard overview of the apparatus from your demonstrators and then PLAY AROUND with the apparatus. I always worked well shoved away in a corner working on my own, for instance when my lab partner didn't show up, since then it was just my own little project to crack on with and had no choice but to, quite literally, EXPERIMENT. Writing this i think it sounds daft, but it's very easy to just resign yourself to not understanding the experiment, especially when there's 2 of you think the same.
As for a difficult lab partner, or one equally as dumbfounded and reluctant to just try things out, I'm not sure what the best ploy actually is.. perhaps asserting yourself and then dragging him into the work by your own getting on with it, or if your partner is a bit of a domineering swine then.. well.. they're the tricky ones, especially if they're good, but I think that little bit extra time in the library before your next day of practical will have you on track
On Googling 'experimenting' I was pleased to discover that more women are now experimenting with bisexuality. I also discovered a nice little aphorism:
I hear, and I forget.
I see, and I remember.
I do, and I understand.
This comes courtesy of Confucius.
I graduated with a BSc in Physics in 2020. Since there were limited opportunities in my country (mostly teaching), I decided to improve my programming skills and began working in IT, first as a software engineer and later as a quality assurance engineer, where I’ve now spent about 3 years. While this career path has provided financial stability, I’ve realized that my excitement and passion aren’t really there, unlike what I felt when studying or doing research in physics. Working in IT...
Hi everyone! I'm a senior majoring in physics, math, and music, and I'm currently in the process applying for theoretical and computational biophysics (primarily thru physics departments) Ph.D. programs. I have a 4.0 from a basically unknown school in the American South, two REUs (T50 and T25) in computational biophysics and two semesters of research in optics (one purely experimental, one comp/exp) at my home institution (since there aren't any biophysics profs at my school), but no...
