Proton Mass-Energy: E=mc^2 Explained
  • Context: Undergrad
  • Thread starter Thread starter Sakha
    Proton
The discussion centers around the mass-energy equivalence of protons as described by the equation E=mc^2, exploring its implications in high-energy physics, particularly in the context of particle accelerators like the LHC. Participants examine the relationship between mass, energy, and velocity, and how these concepts apply to particles in motion.
  • One participant questions whether a proton's energy is independent of its velocity when using E=mc^2, noting the proton's mass and its energy at high velocities.
  • Another participant introduces the complete energy equation, E = √((m₀vc/√(1-v²/c²))² + (m₀c²)²), emphasizing that E=mc² only accounts for rest mass energy.
  • A different participant presents an alternative form of the energy equation, E² = m²c⁴ + p²c², clarifying that p represents relativistic momentum and includes the gamma factor.
  • Some participants express surprise that the full energy equation is not commonly presented in educational contexts.
  • One participant raises a question about the applicability of the wave equation c = λν for all particles, referencing the de Broglie hypothesis that suggests all particles have an intrinsic wavelength.
  • Another participant provides context about the rest-mass energy of protons and compares it to other particles, discussing the energy levels achieved in the LHC and their implications for particle creation.
Participants exhibit a mix of agreement and disagreement regarding the interpretation of mass-energy equations, the applicability of these equations to moving particles, and the relevance of the de Broglie hypothesis. No consensus is reached on the implications of these equations in practical scenarios.
Some participants note the complexity of the equations and the potential for misunderstanding when simplified. There is also mention of the lack of discussion about the LHC's recent activities, suggesting a possible gap in engagement with current experimental physics.
Sakha
After some learning on atomic physics, I came with the following question.
Proton mass is 1.67262158 × 10E-27 kilograms, and its velocity is proportional to its energy. So then, in E=mc^2, you only plug the m, and you will always get the same value. I don't quite understand that a proton approaching to c has about 7 TeV (I got that from an LHC article). So then, according to E=mc^2, a proton (and every other particle) has the same energy independently of its velocity?
E=mc^2 is only half the story. The full equation for total energy is:
[tex]E = \sqrt{\left(\frac{m_o v c}{\sqrt{(1-v^2/c^2)}}\right)^2 + \left(m_0c^2\right)^2}[/tex]
When the particle is at rest and v=0 the equation reduces to the familiar E=mc^2 which is the energy due to the rest mass [itex](m_o)[/itex] of the particle.
The full equation is difficult to get on a T shirt or incorporate into a catchy tune :-p
An easier-to-remember form of that equation is:
[tex]E^2 = m^2 c^4 + p^2 c^2[/tex]
...with the understanding that m stands for rest mass and p stands for the relativistic momentum, which is like classical momentum multiplied by gamma (i.e. [tex]p = mv/\sqrt{1 - v^2/c^2}[/tex])
edit: actually kev made a small error in typing the equation, that 1-v^2/c^2 in the denominator of the parentheses should be in a square root.
edit#2: by the way, another simple form of the equation for the energy of a moving object is [tex]E = \gamma mc^2[/tex], where the gamma factor is given by the usual [tex]\gamma = 1/\sqrt{1 - v^2/c^2}[/tex]...a little algebraic manipulation will show it's equivalent to the first equation I quoted.
Oh.. I had absolutely no clue about that. It's weird that in most cases they never show the real formula.
Well, E=mc^2 is the real formula for the energy of a particle at rest (you can see that if the momentum p = 0, then the formula I posted reduces to E = mc^2), it just doesn't give you the additional kinetic energy for a moving particle.
Oops, your right :blushing: I have edited the post to correct the mistake :redface:
P.S. I gave the non simplified equation with v explicitly stated so that Sakha could insert a value for v and check the validity of the equation against the information he has gleaned from the LHC.
P.P.S. I am surprised that there is so little mention of the LHC in this forum or the Cosmology forum considering it was switched on a few days ago after many years in the making and billions of dollars. Is there that much lack of interest or is everyone just patiently waiting for solid results?
Another little question..
I know that c = [tex]\lambda \nu[/tex] for photons, but does v =[tex]\lambda \nu[/tex] for everything?
Yes, wavelength [tex]\lambda[/tex] is the distance between peaks of the wave, frequency [tex]\nu[/tex] is the rate at which successive peaks are passing a given position (number of peaks per second, say), which is just 1/(time between successive peaks). Naturally, the speed at which the peaks are moving is (distance between peaks)/(time between peaks), so that's wavelength*frequency.
I asume you know about the de Broglie hypothesis that all particles (not just photons) have an intrinsic wavelength?
"Waves of molecules
Recent experiments even confirm the relations for molecules and even macromolecules, which are normally considered too large to undergo quantum mechanical effects. In 1999, a research team in Vienna demonstrated diffraction for molecules as large as fullerenes[8].
In general, the De Broglie hypothesis is expected to apply to any well isolated object."
http://en.wikipedia.org/wiki/De_Broglie_wavelength
The rest-mass energy of a resting proton is about 938 MeV, from resting Electron 0.511 MeV. If you set them in motion the Kinetic Energy will add into it as JesseM explained.
To compare, the energy of visible light is 2-3 eV.
In LHC (Large Hadron Collider) they smash protons with an relative ENERGY of 7 TeV to generate particles (relative to lab 2 x 3.5 TeV - to make it more efficient by making total momentum 0). "Theoretically" the 7 TeV would be enough to create 7000/0.938 = 7450 protons!
They try to detect Higgs particles with - as theory predicts - a mass energy of 500 GeV.
What they do is, annihilating protons to pure energy and hope that that energy will generates new particles (with mass), according to E <=> mc2 or m = (1/c2) E!
Take care
David
  • · Replies 16 ·
  • · Replies 26 ·
  • · Replies 55 ·
  • · Replies 17 ·
  • · Replies 30 ·
