Physical Chemistry: Extracting information from spectroscopic data
In summary, the length of the space L in nanometers is 10.1 nm, found by using the equation for the energy of the particle in a box and the energy of the transition between two states.
quantumech
I need help with extracting information from spectroscopic data. Here is the type of question I am trying to understand:
We have an energy level expression for the particle-in-a-box, which is
En= n2*h2 n=1, 2, 3
. 8mL2
h = Planck’s constant, m = mass of the particle in kg, and L = the length of the
box in m. If an electron is trapped in a one-dimensional space of length L, and shows an
absorption at 523 nm due to the transition from ψ2 --> ψ3, what is the length of the space L in nanometers?Even if I just get a general idea of how to do this so I can compare my answer to it I will really appreciate it.
Thanks
!The solution to this problem can be found using the equation for the energy of the particle in the box and the energy of the transition between the ψ2 and ψ3 states. The energy of the transition can be found using the equation:E = hc/λ, where h is Planck's constant, c is the speed of light, and λ is the wavelength of the absorption. Substituting this into the energy level expression, we get:n2*h2 = hc/λRearranging this equation, we get:L = (hc/n2*h2)*λSubstituting in the values from the question, we get:L = (6.626 x 10-34 x 3.00 x 108)/(9 x (6.626 x 10-34)2 x 5.23 x 10-7)L = 1.01 x 10-9 m = 10.1 nm
First, it is important to understand the concept of spectroscopy and how it relates to physical chemistry. Spectroscopy is a technique used to study the interaction between matter and electromagnetic radiation. It provides information about the energy levels and transitions of a system, which can be used to extract valuable information about the system's properties.
In this case, we are dealing with the particle-in-a-box model, which is a simplified representation of a particle confined in a one-dimensional space. The energy levels of this system are given by the expression En = n^2*h^2/(8mL^2), where n is the energy level, h is Planck's constant, m is the mass of the particle, and L is the length of the box.
Now, to extract information from spectroscopic data, we can use the fact that the energy of a photon is directly related to its wavelength by the equation E = hc/λ, where h is Planck's constant, c is the speed of light, and λ is the wavelength. This means that the energy difference between two energy levels can be calculated by taking the difference of their corresponding wavelengths.
In this case, we are given that the transition from ψ2 to ψ3 results in an absorption at 523 nm. Using the above equation, we can calculate the energy difference between these two levels as follows:
ΔE = hc/λ = (6.626 x 10^-34 J*s)(3.00 x 10^8 m/s)/ (523 x 10^-9 m) = 3.80 x 10^-19 J
Now, we can equate this energy difference to the energy expression for the particle-in-a-box model and solve for L:
ΔE = n^2*h^2/(8mL^2)
3.80 x 10^-19 J = (3^2)(6.626 x 10^-34 J*s)^2/(8(9.11 x 10^-31 kg)L^2)
Solving for L, we get L = 1.39 x 10^-9 m or 1.39 nm.
Therefore, the length of the space L is 1.39 nm.
In summary, to extract information from spectroscopic data, we need to use the relationship between energy and wavelength, as well as the energy expression for the system in question. By equating the two and solving for the unknown variable,
Related to Physical Chemistry: Extracting information from spectroscopic data
1. What is physical chemistry?
Physical chemistry is a branch of chemistry that deals with the study of the physical properties and behavior of matter at the molecular and atomic level. It combines principles of physics and chemistry to understand and explain the fundamental principles governing the behavior of chemicals and their interactions.
2. What is spectroscopy and how is it used in physical chemistry?
Spectroscopy is a technique used in physical chemistry to study the interaction of matter with electromagnetic radiation. It involves the measurement and analysis of the absorption, emission, or scattering of light by molecules or atoms, which can provide information about their structure, composition, and dynamics.
3. How is information extracted from spectroscopic data in physical chemistry?
Information is extracted from spectroscopic data by analyzing the patterns and intensities of spectral lines, which correspond to specific energy transitions in molecules or atoms. By comparing these patterns to known spectra and using mathematical models, scientists can determine the structure, composition, and properties of the sample being studied.
4. What are the different types of spectroscopy used in physical chemistry?
There are several types of spectroscopy used in physical chemistry, including infrared (IR), ultraviolet-visible (UV-Vis), nuclear magnetic resonance (NMR), and mass spectrometry (MS). Each of these techniques has its own strengths and is used to study different types of samples and molecular interactions.
5. What are some real-world applications of physical chemistry and spectroscopy?
Physical chemistry and spectroscopy have a wide range of real-world applications, including drug discovery, environmental analysis, materials science, and forensic science. They are also used in fields such as biochemistry, biophysics, and chemical engineering to understand the behavior of biological systems and develop new technologies and products.
  • STEM Academic Advising
  • Atomic and Condensed Matter
