| Thread Closed |
2^x derivitive |
Share Thread | Thread Tools |
| May19-04, 04:10 PM | #1 |
2^x derivitive
I need to find the derivitive of y=2^x using the definition of derivitive.
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| May19-04, 04:30 PM | #2 |
What have you done so far? What does the definition of derivative say?
| May21-04, 05:28 AM | #3 |
This was also posted in the calculus section and there are about 10 replies there.
| Sep21-04, 08:27 PM | #4 |
Recognitions:
2^x derivitive
I doubt this is a suitable problem for a novice. even showing convergence is tough. i will look at the other posted answers. there is a good reason people start from the integral definition of ln(x) to derive this result.
| Sep21-04, 09:17 PM | #5 |
If f(x)= ax, the f(x+h)= aa+x= axah so
f(a+ h)- f(a)= ax(ah- 1). The derivative is lim (f(x+h)- f(x))/h= axlim {(ah-1)/h}. Notice that that is ax time a limit that is independent of x. That is, as long as the derivative exists, it is ax times a constant. The problem is showing that the lim{(ah-1)/h} EXISTS! And then showing that, if a= 2, that limit is ln(2). Showing that that limit exists is sufficiently non-trivial that many people (myself included), as mathwonk said, prefer to define ln(x) as the integral, from 1 to x of (1/t)dt. From that, it is possible to prove all properties of ln(x) including (trivially) that the derivative is 1/x. Defining ex as the inverse function of ln(x) leads to all the properties of ex (including the fact that it is some number to a power!), in particular that its derivative is ex itself and, from that, that the derivative of ax is (ln a) ax. |
| Oct15-04, 07:23 AM | #6 |
dunno if i'm missing the point here but...
write y=2^x as y=exp(x.ln2) => y'=ln2.exp(x.ln2) |
| Oct16-04, 02:53 AM | #7 |
Mentor
No, you did exactly what HallsofIvy was advocating, he was just pointing out that the question asked for it to be solved using the definition of a derivative, which makes things much harder. Easier to approach things from the other way, starting by defining the integral of 1/x.
| Oct29-04, 12:11 PM | #8 |
"The derivative is lim (f(x+h)- f(x))/h= axlim {(ah-1)/h}. Notice that that is ax time a limit that is independent of x. That is, as long as the derivative exists, it is ax times a constant. The problem is showing that the lim{(ah-1)/h} EXISTS! And then showing that, if a= 2, that limit is ln(2)."
tell me if i'm wrong, but it doesn't seems so hard to determine this limit.. (a^h-1)/h = (exp (h*ln(a) )-1) / h = ( 1 + h*ln(a) + o(h*ln(a)) - 1 ) / h h->0 = ln(a) + o(ln(a)) so lim (a^h-1)/h = ln(a) ....... |
| Oct29-04, 01:32 PM | #9 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: 2^x derivitive
| derivitive problems | Calculus & Beyond Homework | 7 | ||
| Simple Derivitive | Calculus & Beyond Homework | 3 | ||
| Derivitive | Introductory Physics Homework | 2 | ||
| derivitive of 2^x | Calculus | 18 | ||
| Need Anti-Derivitive Help | Calculus | 5 | ||
