I finding my mistake moment of inertia
The discussion centers on the calculation of the moment of inertia for a hollow cylinder with mass M, outer radius R2, and inner radius R1. The correct formula is I = 0.5(M)(R2^2 + R1^2). The user initially miscalculated by incorrectly manipulating the equation for mass, leading to confusion in the final steps. The key correction involves recognizing that M should be in the numerator rather than the denominator when deriving the moment of inertia.
  • Understanding of moment of inertia concepts
  • Familiarity with integration techniques
  • Knowledge of cylindrical coordinates
  • Basic principles of mass density (sigma)
  • Review integration techniques for calculating moment of inertia
  • Study cylindrical coordinate systems in physics
  • Learn about mass density and its applications in mechanics
  • Explore common mistakes in physics calculations and how to avoid them
Students in physics, mechanical engineers, and anyone studying rotational dynamics will benefit from this discussion.
dswatson
How do i prove,using integration, that the moment of inertia of a hollow cylinder that has mass M, an outside radius R2, and an inside radius R1 is given by...
I=.5(M)(R2^2+R1^2)
here is the work I have done...
I am really close but do not see where I made my mistake
Can someone help me find it?
If you look at the cylinder like a bunch of hoops stacked together then
I(hoop)=MR^2
dV=(2*pi*R)(dR)(L)
P=sigma
P=dM/dV
dM=(2*pi*R)(dR)(L)(P)
I=int(R^2*dM)
I=int[a,b](R^2)(2*pi*R)(dR)(L)(P)
I=(2*pi*L*P)*int[R1,R2](R^3dR)
I=(2*pi*L*P)*[(R2^4-R1^4)/4]
I=(pi*L*P)*[(R2^2-R1^2)(R2^2+R1^2)/2]
V=pi*L(R2^2-R1^2)
M=pi*L*P(R2^2-R1^2)
(R2^2-R1^2)=(pi*L*P)/M
I=(R2^2+R1^2)/2M
I have most of the equation correct but M is in the denominator when if needs to be just the opposite
Thank you in advance
Hi there,
Everything is fine up to the last two steps.
From M = pi*L*P(R2^2 - R1^2) you should get M/(pi*L*P) = (R2^2 - R1^2) and not (pi*L*P)/M = (R2^2 - R1^2).
When you change this you should get the right answer.
Don't worry about it, it's just a small mistake. So, you shouldn't get penalized heavily in an exam for it.
I make mistakes like these all the time. The way to avoid them is to always double-check all the steps in your calculations.
Hope this helps,
Wynand.
