| Thread Closed |
Help me please!!!!!!! |
Share Thread | Thread Tools |
| May23-04, 03:38 AM | #1 |
Can you help me to solve this:
(dē e(r)/drē)+(1/r)*(d e(r)/dr)=0 There is no initials conditions, please use general form |
| May23-04, 03:44 AM | #2 |
Hint:
Convince yourself of the following equality: [tex]\frac{d^{2}e}{dr^{2}}+\frac{1}{r}\frac{de}{dr}=\frac{1}{r}\frac{d}{dr}( r\frac{de}{dr})[/tex] |
| May23-04, 03:57 AM | #3 |
And, if i want to find the general form of e(r)?
| May23-04, 04:10 AM | #4 |
You get:
[tex]\frac{d}{dr}(r\frac{de}{dr})=0[/tex] This differential equation can be directly integrated to find the general solution. |
| May23-04, 04:50 AM | #5 |
If I understand, you've made:
1/r*d/dr*(r*de/dr)=0 so: d/dr*(r*de/dr)=0 If i integrate, i find: e(r)=A*ln(r)+B Wrong or not ? |
| May23-04, 05:56 AM | #6 |
THANKS!!!!! you save me!!!
| May23-04, 07:50 AM | #7 |
I would also do it this way:
Rewriting: [tex]e''+\frac{1}{r}e'=0[/tex] I would then multiply through by r^2: [tex]r^2e''+re'=0[/tex] I would recognize this as a d.e. of the Euler-Cauchy form: [tex]x^2y''+axy' + by=0[/tex] In the case of the given equation, a=1 and b=0. The characteristic equation for the Euler-Cauchy is: [tex]m^2+(a-1)m+b=0[/tex] In our case: [tex] \begin{align*} m^2&=0\\ m&=0 \end{align*} [/tex] For the case of a real double root in the characteristic equation, the general solution for the Euler-Caucy is given as: [tex]y=(A + B\ln x)x^m[/tex] So in our case: [tex] \begin{align*} e(r)&=(A + B\ln r)x^0\\ e(r)&=A + B\ln r \end{align*} [/tex] I guess this solution depends on having the Euler-Cauchy form available to you in your course, which may not be the case. |
| May23-04, 04:32 PM | #8 |
Another way to do this problem is let u= e' so that u'= e" and the equation reduces to the separable first order equation u'+ (1/r)u= 0. Then du/u= -dr/r and so
ln(u)= -ln(r)+ C1 or u= e'= C1/r. Integrating again, e= C1ln|r|+ C2. |
| Thread Closed |
| Thread Tools | |
