How Does the Timing of CLK Influence J-K Flip Flop Waveforms?
The timing of the CLK in a J-K flip-flop is crucial for understanding its waveform behavior, as transitions occur only on the rising edge of the clock signal. When J=K=0 and the CLK is high, the output Q remains unchanged, reflecting the current state of the flip-flop. In contrast, when J=K=1 at the rising clock edge, the flip-flop toggles its state. The confusion often arises from not recognizing that the flip-flop's state is stable until the next clock edge. Understanding these timing relationships is essential for grasping how J-K flip-flops function.
bec13
I understand that the truth table involved, and how it works, but i don't get the timing of the diagrams. I've looked on numerous internet sites and through many books but i still don't understand how when J=K=0 and CLK= up, with Q having no change, that the out put (Q) is up, when the others are down. My confusion continues throughout the entire waveform, mostly i believe, as i do not understand the timings of the CLK.
Is there a set time of CLK between each of the inputs? Basically, i would just like a straight answer to explain to me how the waveform works:)
http://en.wikipedia.org/wiki/Flip-flop_(electronics)#JK_flip-flop
Note that transitions in the flip-flop state occur only on the rising clock edge, not when the clock is stable. Additionally, the particular case you ask about, J=K=0 with a rising clock edge (and not a HIGH clock) holds the present state of the flip-flop. J=K=1 with a rising clock edge causes the flip-flop state to toggle. Why? That's the defined function of the J-K flip-flop.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
