Calculating Angle in Two-Slit Experiment with High-Speed Protons
In a two-slit experiment involving protons traveling at 0.825c, the wavelength is calculated using the relativistic momentum equation, p = mv, leading to a wavelength of approximately 1.6E-15 m. The angle for the second minimum is determined using the formula d*sin(theta) = (m + 1/2)*lambda, where m is set to 1. The initial approach yielded a very small angle, prompting a discussion on the need for relativistic calculations. It was clarified that small angles can be valid, but larger angles require slit separations comparable to the wavelength. The correct angle was ultimately found using the appropriate relativistic momentum considerations.
nnof55
A stream of protons, each with a speed of 0.8250c, are directed into a two-slit experiment where the slit separation is 2.00 10-9 m. A two-slit interference pattern is built up on the viewing screen. What is the angle between the center of the pattern and the second minimum (to either side of the center)?
p = mv
lambda = h/p
I have tried to first solve for the wavelength in the experiment by using p = mv. With this I get:
p = (1.673E-27)*(0.8250)*(3E8)
p = 4.14E-19
Then I solve for the wavelength using lambda = h/p:
lambda = (6.63E-34) / (4.14E-19)
lambda = 1.6E-15
Once I have the wavelength, I use the double slit formula from Young's Experiment to try and calculate the angle, by using m = 1 and then solving for arcsin:
theta = arcsin ( m*lambda / d)
theta = arcsin ( 1.5*(1.6E-15) / (2E-9))
However this gives me a very small angle which obviously is the incorrect answer.
Am I approaching this completely wrong, or am I just goofing up somewhere?
Welcome to PF!
For protons at 0.825c, you might want to calculate the relativistic momentum
Thanks! I was able to calculate the correct angle using the relativistic momentum equation!
Also, a small angle is not necessarily incorrect. To obtain large angles, the slit separation has to be comparable to the wavelength of the wave. Particles with large momenta will have very small wavelengths.
