Find the mass of object knowing the applied force and coefficient of friction
The problem involves determining the mass of an object given the applied force and the coefficient of friction. The context is rooted in the principles of friction and Newton's laws of motion.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the relationship between the applied force and the frictional force, questioning how to utilize the given values without knowing the mass. There is exploration of the equations relating friction, mass, and acceleration.
Some participants have provided guidance on interpreting the applied force as equal to the frictional force, while others express confusion regarding the implications of this relationship. There is an ongoing exploration of the relevant equations and their application.
Participants note the challenge of working with the given information, particularly the lack of mass and acceleration, which complicates the use of standard equations in this context.
liz777
If a force of 45 Newtons is needed to overcome friction and the coefficient of friction=0.26, what is the mass of the object?
So would I need to find the frictional force first? But then I can't use the equation: (frictional force=coefficient of friction x weight) since I don't have the mass. I also thought about using the equation F=MA but then I don't have the acceleration, the friction, or the net force! Any help, I'm really stuck?
They give you the friction force. The way to interpret the given information is that the 45 N force is just enough to overcome friction, thus that force equals the friction.
Sure you can use that equation. Remember that you're asked to find the mass.
Ok, so what you're saying is that the applied force equals the friction, in this case. I thought it wouldn't move though if that was true? I'm just confused on this concept.
But anyway, using that information, frictional force=coefficient of friction x weight
45=0.26m(9.8)
45=2.55m
m=17.65kg
Is that right?
Yes.
You are given two values, and you need to solve for one of them using an equation with four variables, three of which are known (the other being g).
