Mirror Reflexion: Does Photon Remain Unchanged?
  • Context: Undergrad
  • Thread starter Thread starter live4physics
    Photon
The discussion revolves around the nature of photon reflection in mirrors, questioning whether a reflected photon remains unchanged and exploring the underlying atomic processes involved. The scope includes conceptual and technical aspects of photon behavior during reflection.
  • Debate/contested, Conceptual clarification, Technical explanation
  • One participant questions if a reflected photon is the same as the incoming photon, suggesting there may be atomic processes involved.
  • Another participant argues that since all particles are identical, the question of whether a photon is the same after reflection is meaningless, as no experiment can determine this.
  • A similar point is reiterated, with an additional inquiry into whether the photon is "reflected" at the atomic level and if magnetic phenomena play a role.
  • It is noted that light cannot penetrate a conductor, leading to the conclusion that conduction electrons move to cancel electric fields, resulting in reflection from the surface, described as a basic electrostatic principle.
  • A later reply introduces the idea that an incoming photon is absorbed by an electron in the mirror and then re-emitted, leaving the interpretation of whether this constitutes the "same" photon open to personal interpretation.
Participants express differing views on whether a reflected photon can be considered the same as the incoming photon, with no consensus reached on this matter.
There are unresolved questions regarding the atomic processes involved in reflection and the implications of particle identity in this context.
live4physics
In case of mirror reflexion, a photon reflected is the same ?
There´s some atomic process in this fenomena ?
:blushing:
As all particles are identical
the question 'is it the same' does not have any sense, because there is no experiment in principle which can determine if it is the same or not.
I mean, is the photon "reflected" at atomic level ?
There´s a magnetic fenomena in this ?
light can't penetrate a conductor. the conduction electrons will move so as to cancel out any electric field in the conductor. as a result the light is reflected from the surface. this is basic electrostatics
live4physics: the incoming photon is absorbed by an electron in the mirror, and then re-emitted almost immediately. Whether you consider this to be "the same" photon or not I suppose is up for personal interpretation.
  • · Replies 38 ·
  • · Replies 76 ·
  • · Replies 24 ·
  • · Replies 18 ·
  • · Replies 26 ·
