Find the coefficient of kinetic friction?
The discussion revolves around calculating the work done by a baseball caught in a glove and finding the coefficient of kinetic friction between a flight bag and the floor. The work done by the baseball is determined to be 54.056 J, while the work done by friction is reported as -5285.02 J, though its relevance is questioned. Participants express confusion over the problem's details, particularly regarding the mass of the flight bag and its movement. Clarification is sought on whether the glove is stationary or in motion, as this affects the ability to calculate the coefficient of friction. Overall, the lack of complete information hinders the solution process.
kadavis2010
A catcher “gives” with a baseball when catch-
ing it.
If the baseball exerts a force of 466 N on the
glove such that the glove is displaced 11.6 cm,
how much work is done by the ball? Answer
in units of J.
(I got this answer and it is 54.056)
Find the coefficient of kinetic friction be-
tween the flight bag and the floor.
Thats what i don't know...
I don't know how to do
There seems to be something missing in your statement of the problem(s). Is the glove sitting on a flight bag and the bag and glove slide? Is the glove being held by a person?
I just copied and pasted the problem off of online. That is all that is says.. It does say "Find the work done by the force of friction on the flight bag. Answer in units of J." But i found that answer being -5285.02... I don't think that's important though..
I'm curious, do you have the mass of the flight bag? Was the flight bag caused to move by the baseball? I'm not being silly. As stated above, you can't find the coefficient of friction. To tell you the truth I have no idea where you came up with the work done by the force of friction: -5285 J.
Well it is a online assignment and we have to submit the answers in the answer blank. Not that i look at it though i have no idea where i got -5285 from but it was right.. I know there is an answer to it because some of my friends worked with the teacher and got the answer but they don't know how to help me answer it.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
