Thevenin Equivalent for circuits with dependent sources
The discussion focuses on finding the Thevenin equivalent of a circuit containing a dependent current source. The user initially struggled with applying the superposition theorem due to the presence of dependent sources. A solution was proposed involving Node-Voltage analysis, specifically using KCL at the node with the dependent source and formulating equations for the unknown voltages. This method provides a systematic approach to determine the Thevenin voltage (Vth) and resistance (Rth) for the circuit.
  • Understanding of Thevenin's Theorem
  • Familiarity with dependent sources in electrical circuits
  • Knowledge of Node-Voltage analysis
  • Ability to apply Kirchhoff's Current Law (KCL)
  • Study the application of Thevenin's Theorem with dependent sources
  • Learn advanced Node-Voltage analysis techniques
  • Explore Kirchhoff's Current Law (KCL) in complex circuits
  • Review examples of Thevenin equivalents in circuit analysis textbooks
Electrical engineering students, circuit designers, and anyone involved in circuit analysis who needs to understand Thevenin equivalents with dependent sources.
shanrei
Hi!
Good day! I was studying Circuit Theorems when I stumbled upon this circuit that has a dependent current source asking for a Thevenin equivalent. Up until now, I was only familiar with solving circuits with independent sources so this has me having a hard time. I tried using superposition theorem to solve for Vth but my answers don't match with the given answers. Can anyone please help me with this? Here is the pic for the circuit.
http://img230.imageshack.us/img230/3359/picture1um7.th.jpg
Thanks in advance!
Did you do KCL at node X (where the dependent current source is going into)? Can you see the relationship of voltage at this node to the current going out of the node? (Ix going into 3 and 4 ohms)
First I would remove the sources and solve for the Rth.
Next I would use Node-Voltage analysis on the original circuit:
-use the node on the negative side of the voltage source as your reference node
-now the only nodes with unknown voltages are the upper-middle node and upper-right node, label as V1 and V2, respectively.
-write the constraint equation for Ix
-write the KCL equations for nodes V1 and V2
-solving these 3 equations for the 3 unknowns should give you the information needed to find this circuit’s Vth
I hope that helps you get the correct answer, and that I described it correctly :bugeye:
  • · Replies 42 ·
12K
