| Thread Closed |
roulette probability |
Share Thread | Thread Tools |
| Feb7-09, 04:56 PM | #1 |
I'm not a math whiz but I would like to know how to calculate this and similar things. if you have a roulette wheel with 37 spots where the ball can land. If you have a limited number of spins, say 10 spins. what is the probability that the same number will appear two times, three times, etc. ? I know one time would be 1/37. but I don't know how to calculate the probabilty of the same number occuring more than once in a fixed number of spins.
T.D. |
| Feb7-09, 05:31 PM | #2 |
The wheel doesn't have double aughts?
That's a probability of 1 in 37 for one spin, where the number is given in advance. Assumed is that each outcome of a spin is independent of other outcomes. To get a prepicked number exactly 3 times in 5 spins, independent of order, means that in 2 spins the number does not turn-up. P = (1/37)(1/37)(1/37)(36/37)(36/37) |
| Feb7-09, 05:58 PM | #3 |
Don't you also have to consider the possible order of outcomes?
YYYNN YNYNY YNNYY ... etc so 5C3 = 10. Multiple that probability by a factor of 10? |
| Feb7-09, 10:32 PM | #4 |
Yes, you're right, Rip.
| Feb7-09, 11:23 PM | #5 |
European wheel only has one zero.
Thanks for the lesson. So if order doesn't matter then this is correct for 3 occurences out of five ? (1/37)(1/37)(1/37)(36/37)(36/37) I know every bet in roulette has a negative expectation, but there is something called the andruchi system (see google) that has some interesting looking probability analysis and I was wondering how to do the actual calculations to properly analyze it. thanks for the tutorial T.D. |
| Feb8-09, 02:02 AM | #6 |
See 'math combinations' to get C(5,3)=10 |
| Feb8-09, 07:00 AM | #7 |
P = ( (1/37)(1/37)(1/37)(36/37)(36/37) * 5 ) |
| Feb8-09, 07:11 AM | #8 |
BTW,
This is the classic binomial probability distribution: en.wikipedia.org/wiki/Binomial_distribution |
| Feb8-09, 09:13 AM | #9 |
binomial distribution, that looks like what I was after
thanks everyone T.D. |
| Jun19-10, 11:23 PM | #10 |
Hello TalonD and all,
According to the P=10(1/37)(1/37)(1/37)(36/37)(36/37) posted above, the probability of a specific number appearing at least one time in 37 spins would be: P= 37 (1/37) (37/37) (37/37)......(37/37) = 37(1/37)(37/37)^36=37(1/37)=1 which of course is incorrect. What did I do wrong in interpreting the initial equation? I would calculate the probability of a specific number appearing at least one time in 37 spins as: P= 1-(36/37)^37 ps:the andruchi system is no better than any other system inho |
| Jul26-10, 05:00 AM | #11 |
Hi There
I wonder if someone can help me with this roulette wheel command. I have to solve a problem in matlab using a set of algorithms. If I have two algorithms then I use rand() command to choose one of them randomly but if I have more than two algorithms I need to use this roulette wheel command but I am not a programmer so having problem how to use this roulette wheel command. Suppose I have set of 4 algorithms and I have to use one of them to solve the problem choosing one of these four algorithms. I'll be grateful for your help. I can upload the M-file if anyone wants to see the whole directory and set of algorithms. Thank you all in advance. Farooq |
| Thread Closed |
| Thread Tools | |
Similar Threads for: roulette probability
| Roulette ball trajectory (after impact) | Introductory Physics Homework | 2 | ||
| Here is the roulette cheat cookbook (Fake?) | General Physics | 8 | ||
| roulette F=mv^2/r | Classical Physics | 0 | ||
| Roulette | General Physics | 1 | ||
| Man bets all on Las Vegas roulette spin | General Discussion | 5 | ||
