| Thread Closed |
few questions about surface area and volume |
Share Thread | Thread Tools |
| Feb14-09, 09:48 AM | #1 |
When calculating the volume of a sphere, what does (4/3) represent? Why is it (4/3) * pi * r^3 .. and not some other number/fraction?
I'm also curious about the surface area of equilateral triangle. Why is it sqrt(3)/4 * a^2 ... What does sqrt(3)/4 physically represent in the geometry? |
| Feb14-09, 10:01 AM | #2 |
Well, if you rewrite the volume for the ball as [tex]V=\frac{1}{3}*4\pi{r}^{3}[/tex], recognize that this can be further simplified as:
[tex]V=\frac{1}{3}*r*S[/tex] where S is the surface area of the sphere. Thus, the volume of the ball is equal to the volume of a cone of height "r" and base area S. This is the gist result of how Archimedes proved the formula. |
| Feb14-09, 10:41 AM | #3 |
Thanks. Here's what I just came up with for a possible physical (?) representation..
since, pi is the same as (2*pi*r)/(2*r) V = ((4) * (2*pi*r) * (r^3)) / ((3) * (2*r)) or V = (8 * pi * r^4) / (6 * r) V = (4 * circumference) / (6 * radius) Would the numerator represent 4 dimensions? Seems weird. |
| Feb14-09, 04:36 PM | #4 |
| Feb14-09, 05:19 PM | #5 |
I meant,
V = (4/3 * pi * r^3) = (8 * pi * r^4) / (6 * r) Which could be considered a ratio between whatever (8 * pi * r^4) is .. and (6 * r) which is (3 * Diameter) disregard this: cowah22 was my secondary ID. |
| Feb14-09, 09:21 PM | #6 |
Does that make sense?
| Feb15-09, 08:08 AM | #7 |
Yes, but then you re-wrote 8*pi*r4 as 4*circumference. So it must be circumference = 2*pi*r4.
I think you're reading too much into what's essentially a constant created by integration (r2 -> r3/3, and the 4 comes from the surface area of a sphere formula) |
| Feb16-09, 10:04 AM | #8 |
Probably. Does (8*pi*r^4), or (Volume * (3*Diameter)) even have any geometric meaning/significance? I just thought it was interesting to see a 4th dimension in a sphere volume equation. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: few questions about surface area and volume
| Arclength, Surface Area and Volume | Calculus | 2 | ||
| Surface w/ max volume and min surface area | Calculus | 13 | ||
| Integrals of surface area/volume | Calculus | 3 | ||
| Surface Area and Volume Relationships? | Calculus | 5 | ||
| Surface Area vs Volume in Biology | Biology | 11 | ||
