Help me get an eyelash out of my eye
  • Thread starter Mk
  • Tags
    Eye
In summary, the person's eye was stabbed by an eyelash and they are considering going to an ophthamologist because they are afraid of damaging their eye.
Mk
2,043
Last night there was something sharp in my eye and I messed around with it for a few minutes by blinking a lot popping my eyelid and rolling my eyeballs around. It didn't come out but when it got to a more comfortable position, I went to sleep, hoping it would automatically come out.
Turns out, on waking I find out that it is an eyelash stuck in there, a long one. Not only that, but it is barely peaking out of what's a good way beyond the skin and flesh. Only a little bit is sticking out, the rest is "behind" my eye, rolling on the surface of my eyeball I suppose.
I don't think it would be a good idea for me to make it go further back there. It's at a more comfortable position now that it isn't stabbing into anything, but I don't like the idea of something that isn't my eye being inside my optical cavity. What should I do? Should I really go to an ophthamologist over an eyelash?
Ouch, Mk, that sounds awful! Yes I would definitely go see a doctor. You could damage your eye by digging around too much...let a professional do it.
Digging? That sounds scary, I was thinking this:
What I usually do is get a paper towel wet (like soaking wet and dripping all over the place), hold it to the inside corner of my eye, and squeeze out the water. It's a little messy, but it usually flushes out your eye enough to get rid of the offending eyelash, plus it can help with any irritation that the eyelash caused.
But it's a little bit far in there and is sticking in the mucus/eyewater I think.
Try flushing your eye out with water. Sometimes when the eyeball is well lubed the eyelash will float to the forefront. Then you can gently touch it with your finger and it will stick to it. Make sure you wash your hands first.
I second this... hold your eye open by pushing up on your eyebrow and down on your cheek, then liberally spash water into the eye with your other hand. I even got some really nasty wood splinters out out my eye (with no damage) by massive flushing. (I had on safety goolgle while drilling... but the porch was old and dropped splinters even AFTER I was done drilling had had the swing installed. Don't look up while swinging on a swing installed on an old porch... especially if the swing seems to be falling out!)
Edited to add: You don't want to dig and end up looking like Tom's avatar!
A long time ago, my father bought a glass cup specifically designed for flushing the eyes. It looked like a small glass wine cup, but the top of it was contoured to fit flush around the area of the eye so that when you tilted your head back, while holding the cup over the eye, it would not leak the water out (or maybe just a little). I don't know if they still sell those things, but it was pretty effective.
> Help me get an eyelash out of my eye... PLEASE!
I'm sorry to hear about the problem but seeing this problem posed on physicsforums was severely amusing :biggrin:
Almost like one of the string theory related threads, which had a google supposed "context based ads" in it, with a almost naked lady wearing STRING undies. Now that's puts string theory in a new light. I wonder how many orders they got from string theorists.
/Fredrik
They come with eye washes like Collyrium. I have used this since I was little, my mom had to get a lot of things out of our eyes.
http://www.bausch.com/en_US/ecp/visioncare/product/drops/collyrium_ecp.aspx
I'd hate to have you do anything that would cause you more trouble though.
When flushing, a bit of salt in the water helps. Make sure that it's all dissolved, though.
yes, evo's link is what you want. the eyewash kits are actually ridiculously expensive for what you get (plain saline and a plastic cup), but it works. you want to fill the cup to the brim, tilt your head over 90 degrees, and adhere the cup around your eye so it's immersed. then blink a lot while looking in all directions. gravity and turbulence should wash it out. if that doesn't work, you'll need to try a doc.
If you are afraid of the eyelash working its way behind your eye. Fear not, the bulbar conjunctiva,the clear membrane coating the white(sclera) of your eye, is connected to the bulbar conjunctiva, the membrane that lines the inside of your eye lids. There is no free pathway into the orbit.
A good way to remove a conjunctival foreign body is with a wet q-tip. Don't use a dry q-tip as it will leave cotton fibers behind.
Edit to my post.
The bulbar conjunctiva is connected to the palpebral conjunctiva that lines the eye lids.
Oh darn, I've had this window up for a day, and when I finally come back with my victory story, it tells me my time's expired and deletes it. Agh!
I called an optometrist's office not long after I posted the first post and saw lisab's and Tom's post. The first office didn't know what to do and suggested I come in (yeah, sure), but they gave me the phone number of a closer office. I called that one, and whoever picked up the phone, Bonnie, had a suggestion. She said to take a Q-tip and try and touch the eyelash with it to pull it out. It would work because the eyelash was wet and the q-tip was dry. I tried doing this after two or three minutes of hesitation (I'd be more comfortable with real surgeries than anything touching my eyes). It didn't work. I tapped it again two or three times, and my eye just went "I hate you!" at me.
I tore off an eyelash of my own and pulled my lip out. I put the eyelash on my wet lip and pressed it in so it was good and wet. I tapped the q-tip a few times against the eyelash to see if it would work. It didn't. I pressed harder and tapped it furiously but the eyelash stood unaffected.
I called my dad. He said to take a hot shower (his remedy for just about everything) and open my eyes in the water stream. So, I tried it. I shampooed my hair and rinsed it out, then after a few more seconds of hesitation, I stuck my face in and tried opening my eyes. My eyes felt pretty closed, but I think they were more open than how they felt. I pulled out and my eyes were all stinging, but I dried them off and tried again. After that I hopped out and checked in the mirror ready to see it either totally gone, or completely unaffected. I pulled my flesh open and... it moved! So I went back in the shower and did it again two more times. I looked in the mirror again and the eyelash was just barely out, and over the skin. I used my finger to slide the eyelash out all the way, and held the conquered eyelash on my fingertip. I sang Viking victory songs and ate chocolate cake the end. :smile:
And thanks a lot larkspur, I was afraid in the beginning that if I touched it too much I might drive it further backwards, warranting an actual necessary doctor's visit. After enough eyeball rolling, I noticed however much I pushed it in the backwards direction, it eventually stopped and stayed in that one place.
Next time, just go ahead and ask your Dad first.
That's what I learned out of all this! I did not call him though, because I could not find his work phone number, and it was not lunch time for him yet. :smile:
Find someone to kick you in the jewels and then cry it out.
Related to Help me get an eyelash out of my eye
What Should I Do if I Have an Eyelash in My Eye?
Having an eyelash in your eye can be uncomfortable, but it's essential to handle it carefully to avoid further irritation or injury to your eye. Here's what you can do:
1. Wash Your Hands:
Start by washing your hands thoroughly with soap and water. This step is crucial to prevent any dirt or bacteria on your hands from getting into your eye.
2. Blink Several Times:
Sometimes, a simple blink can help move the eyelash to the corner of your eye, making it more accessible for removal.
3. Use a Clean Tissue:
Gently blot your eye with a clean tissue to see if the eyelash sticks to it. Avoid rubbing your eye, as this can cause further irritation.
4. Try the Blinking Technique:
Hold your upper eyelid and blink rapidly. The motion of blinking might dislodge the eyelash. Be patient and keep blinking gently.
5. Rinse Your Eye:
Use a sterile saline solution or artificial tears to rinse your eye. This can help flush out the eyelash or any other foreign particles. Tilt your head back slightly and pull down your lower eyelid to create a small pocket for the solution. Then, let a few drops of the solution fall into your eye. Blink to distribute the solution and hopefully remove the eyelash.
6. Use a Cotton Swab or Corner of a Clean Cloth:
If the eyelash is still in your eye, you can try using the corner of a clean cloth or a cotton swab to gently touch the eyelash and coax it out. Be extremely gentle to avoid scratching your eye.
7. Seek Help from Someone:
If you're unable to remove the eyelash on your own, you can ask someone you trust for assistance. They can use a clean cotton swab or the corner of a clean cloth to help remove the eyelash.
8. Do Not Use Sharp Objects:
Avoid using tweezers, sharp tools, or anything that could potentially harm your eye. These items can cause injury or make the situation worse.
9. Consult an Eye Care Professional:
If you are unable to remove the eyelash, experience persistent discomfort, or suspect any injury to your eye, it's crucial to seek help from an eye care professional, such as an optometrist or ophthalmologist.
How Can I Prevent Eyelashes from Getting in My Eye?
While it's not always possible to prevent eyelashes from getting into your eye, you can take some precautions to reduce the likelihood of it happening:
1. Maintain Good Eye Hygiene:
Cleanse your eyelids regularly to reduce the chances of eyelash debris irritating your eyes.
2. Use Protective Eyewear:
If you work in environments with airborne particles or dust, consider wearing safety goggles or protective eyewear to shield your eyes.
3. Trim Your Eyelashes:
If you find that your eyelashes are exceptionally long and prone to getting into your eyes, consider trimming them carefully using small scissors or an eyelash trimmer.
4. Properly Apply Mascara:
If you use mascara, apply it carefully to avoid clumping or excessive application that may lead to eyelash issues.
Remember that if you experience persistent eye discomfort or irritation, it's essential to consult with an eye care professional for a thorough evaluation.
  • General Discussion
  • Atomic and Condensed Matter
