| Thread Closed |
Finding the equation of a graph with asymptotes (help please) |
Share Thread | Thread Tools |
| Feb20-09, 11:38 PM | #1 |
This is the question: Shown in the figure below is the graph of a rational function with vertical asymptotes x=2, x=6, and horizontal asymptote y= -2 . (All x-intercepts of the graph of f are also shown, and a point on the graph is indicated.) The equation for f(x) has one of the five forms shown below. Choose the appropriate form for f(x) , and then write the equation. I can't get the graph on but point are at (-4,0); (0,2); (3,0). 2. Relevant equations The answers choices are: A) f(x)= a / x-b B) f(x)= a(x-b) / x-c C) f(x)= a / (x-b)(x-c) D) f(x)= a(x-b) / (x-c)(x-d) E) f(x)= a(x-b)(x-c) / (x-d)(x-e) 3. The attempt at a solution What I first did was try and get rid of equations that couldn't possible work. So I knew I had vertical asymptotes at x=2,6. I had two asymptotes so I knew that options A and B couldn't work. I then got rid of option C because dividing a by x to get my horizontal asymptote would not give me y= -2 it would give me y=0. I then got rid of option E by factoring the top part through. Since having ax^2 as my leading coificent would give me a diagonal asymptote I got rid of it. So I got D as my answer but then I have to find the equation. So I got (x-2)(x-6) for the bottom because those would give me vertical asymptotes at x=2,6 But I don't know how to find the top. I got -2(x-12) divided by (x-2)(x-6) because sticking 0 in for x would give me 2. So I had the point (0,2) but I can't get any of the others to match up. I'm not sure how to figure it out. |
| Feb21-09, 04:55 AM | #2 |
You are right, that the other points don't match up. To put it in a mathematical way: the set of equations for a, b, c... you get from plugging in the points is overdetermined and does not have a solution. Therefore D is wrong.
I think your argument for getting rid of F is not entirely correct. You are saying, that your leading behaviour is ~ x^2. However, you also have something ~ x^2 in the denominator. Did you learn to take limits yet? Can you properly calculate [tex]\lim_{x \to \infty} \frac{a (x - b)(x - c) }{ (x - d)(x - c) }[/tex] Also note that you will need all the points to determine the constants. To take your (wrong) example of option D: if you plug in x = 0 then you get f(0) = - a b / 12 = 3. Although you get a relation a = -36 / b, this alone will not allow you to determine a and b, you will need at least one other equation. |
| Feb21-09, 05:45 AM | #3 |
Does option F really have "(x- c)" in both numerator and denominator? And what happened to option E?
| Feb21-09, 06:35 AM | #4 |
| Feb21-09, 01:22 PM | #5 |
No I really don't know how to do limits. We've touched on it a little bit last year. But I am in an online pre-calculus course and the program doesn't really explain things in terms I can understand. The program has never shown me how to do this so I have no idea how to do it. I'm completly confused and lost. I'm slow at learning math so most of the time I need it in the simplest terms possible.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Finding the equation of a graph with asymptotes (help please)
| Help finding equation of the tangent line to the graph | Calculus & Beyond Homework | 6 | ||
| Finding an equation of a graph | Calculus & Beyond Homework | 1 | ||
| Finding the Equation of A Graph using Tangents | Precalculus Mathematics Homework | 5 | ||
| Limits and Asymptotes from a graph | Calculus & Beyond Homework | 1 | ||
| finding the equation of a circle from given point on the graph | Precalculus Mathematics Homework | 4 | ||
