Thread Closed
composition of functions
Share Thread
Feb27-09, 09:41 AM   #1
This might be a silly question:
given a function [tex]g[/tex] is it possible to find a function [tex]f[/tex] such that [tex]f = f \circ g[/tex]?
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Feb27-09, 10:36 AM   #2
Quote by mnb96 View Post
f=const.
Feb27-09, 01:22 PM   #3
That is the trivial solution. Perhaps there are others?
f(x) = f(g(x)) if...
f(x) = c, c constant.
g(x) = x, f any function.
If these two conditions don't hold, though...
Assume f has an inverse function. For instance, if f(x) = 2x, then (inv f)(x) = x/2. Then
f = f o g
f(x) = f(g(x))
x = g(x).
So if f has an inverse, g must equal x if f = f o g.
So you'd only be looking for functions which don't have an inverse.
But what we have is a little stronger than that, no? Since my argument makes no reference to intervals, it must be true on any interval. So g = x if you want a function f which is invertible over any interval.
The only function which is not invertible over any interval is - you guessed it - constant functions.
So, in summary:
if g(x) = x, then any function f(x) will do.
Otherwise, f(x) = c , c constant, is the only solution.
What about functions of more variables? Or generalized operations like differentiation? No idea.
Feb27-09, 02:14 PM   #4
If g(x)=x Then f(x) can be anything.
Let
g(n)=2n
Then f(n) can map even numbers to one constant and odd numbers to a different constant. (At least it works if n is discrete). Not sure if it works in the continuous case but I think it might.
Feb27-09, 02:42 PM   #5
Quote by csprof2000 View Post
So, in summary:
What about the following examples?
a) f(x)=abs(x), g(x)=-x
b) f(x)=cos(x), g(x)=x+2pi
Feb27-09, 04:47 PM   #6
Good point.
I guess then that my argument only works for functions which don't have an inverse where Domain(inv f) = Range(f). This, naturally, precludes functions such as abs(x) and cos(x)...
So I guess more though will have to be put into functions which are not bijections.
Feb28-09, 04:06 AM   #7
Thanks a lot. You all made very good observations that helped me a lot.
BTW, it seems that if the function f admits an inverse there are not many choices, while if the function f is not invertible, many solutions exist but the problem is non-trivial, and it is difficult to say what kind of functions f and g would have to be, in order to satisfy f(x)=f(g(x)).
At the moment I am trying to solve the following (similar) problem:
[tex]f = (f \circ g) g'[/tex]
where g is invertible, and g' denotes its derivative
If you find it interesting, suggestions are always welcome.
Thanks!
Feb28-09, 10:57 AM   #8
Well, similar suggestions - cases - are possible.
Assume f(x) = c, c constant. Then c = cg', g' = 1, and g = x + k, k constant.
Assume f(x) = x. Then x = gg', gdg = xdx, and (g^2)/2 = (x^2)/2 + k, k constant.
Assume f(x) = x^n. Then x^n = g^n g', g^n dg = x^n dx, [1/(n+1)]g^(n+1) = [1/(n+1)]x^(n+1) + k, k constant
Wow, that's an alright result. So for x to any power at all, it's possible. Is is true for any polynomial? Yes, it seems like it should be. So... for any polynomial, I believe you can use the above formula to reduce it.
f(x) = cos x, cos x = (cos g)g', (cos x)dx = (cos g)dg, sin(x) = sin(g) + k.
It seems like, unless I'm mistaken, this is the same thing every time:
f(x) = f(g(x))g'(x) is the same as solving the differential equation f(x)dx = f(g(x))dg.
So, as long as f is integrable, the problem is actually quite easy. Maybe I'm wrong. Thoughts?
Mar1-09, 02:24 AM   #9
csproof2000: I think you just made it!
You gave the solution to the problem, and for some reason I didn't immediately spot that what I was trying to do is actually solving a differential equation.
Thanks a lot you all...you made very helpful observations!
Thread Closed
Similar discussions for: composition of functions
Thread Forum Replies
Īnverse functions and composition Calculus 3
Composition of Inverse Functions Set Theory, Logic, Probability, Statistics 8
Composition of functions Calculus & Beyond Homework 3
Composition of 2 functions Set Theory, Logic, Probability, Statistics 6
Composition and Identity of functions Calculus 3
