Thread Closed
Wheelbarrow and load advantage (i think)
Share Thread Thread Tools
Mar11-09, 07:29 AM   #1
A wheelbarrow is holding a mass of 15kg, 35cm from the handle. The fulcrum is located 65cm from the handle. What is the mechanical advantage at the handle?
Handle Load Fulcrum
_______________============_
____________ O (wheel)
2. Relevant equations
I believe it is (f1)x(d1)=(f2)x(d2)
3. The attempt at a solution
Therefore ...
(f1)x(65)=(15)x(30) 30 being the distance from the handle to the centre of load.
(f1)x(65)=450
f1=450 / 65
f1=6.9 kg
Is this correct? I am a complete dummy at physics :(
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Mar11-09, 08:31 AM   #2
no, unfortunately you made a slight calculation error, but the rest is ok. your distance from the handle to the centre of the load is 35, not 30. Also, the term "mechanical advantage" gives me the feeling your answer should be in a ration or percentage form. ie. If I lifted the 15kg mass directly, it's mass is 15kg, if I use the wheelbarrow, it's apparent mass is 6.9kg. Therefore I have a mechanical advantage of 15/6.9=2.17 or (15-6.9)/6.9=117%
Also, the wheel of your wheelbarrow is the fulcrum and it appears to be in a strange positon on your drawing. To approach this problem more accurately, you should draw a free body diagram, state that the system is equilibrium and let the sum of moments about your fulcrum be zero. You'll end up with the same result, but it will be neater and more rigid.
Thread Closed
Thread Tools
Similar Threads for: Wheelbarrow and load advantage (i think)
Thread Forum Replies
Applied ME: Dynamic load calculation, drag force correlation. Load cells and LabVIEW? Mechanical Engineering 8
advantage of both. Brain Teasers 11
Need Confimation on Answer Process for Wheelbarrow Physics Question Advanced Physics Homework 3
mechanical advantage Introductory Physics Homework 10
Being taken advantage of. General Discussion 53
