Chemistry - Entropy Changes in Physical Processes
In summary, the entropy of a system decreases during the processes of purification and mixing, as they involve a decrease in disorder. However, in the processes of freezing and evaporation, the entropy increases due to an increase in disorder. The process of separation also leads to an increase in entropy, as it involves the formation of multiple substances from one.
ncm2
Indicate how entropy of the system changes for each of the physical processes shown below.
Entropy increases, entropy decreases, entropy does not change.
1. Purification
2. Mixing
3. Freezing
4. Evaporation
5. Separation
Entropy increases when it goes from less to more disorder.
Entropy decreases when it goes from more to less disorder.
Purification - many to one substance, so entropy decreases
Mixing - many to one substance, so entropy decreases
Freezing - more to less disorder, so entropy decreases
Evaporation - less to more disorder, so entropy increases
Separation - one to many substances, so entropy increases
These are wrong, but I can't think of why. Help is much appreciated.
Mixing - many to one substance... Do you mean that solution is ONE SUBSTANCE? What do you mean by one substance?
Your responses are mostly correct, but there are a few corrections that can be made.
1. Purification - In this process, the system goes from a mixture of substances to a pure substance. This means that the disorder of the system decreases, so entropy decreases.
2. Mixing - In this process, the system goes from two or more substances to a mixture. This means that the disorder of the system increases, so entropy increases.
3. Freezing - In this process, the system goes from a liquid state to a solid state. This means that the disorder of the system decreases, so entropy decreases.
4. Evaporation - In this process, the system goes from a liquid state to a gas state. This means that the disorder of the system increases, so entropy increases.
5. Separation - In this process, the system goes from a mixture to two or more pure substances. This means that the disorder of the system increases, so entropy increases.
What is entropy in chemistry?
Entropy is a measure of the disorder or randomness of a system. In chemistry, it refers to the amount of energy that is unavailable for work in a process. It is often described as a measure of the "disorder" of a system, with higher entropy indicating a more disordered state.
How does entropy change in physical processes?
In general, the entropy of a system tends to increase in physical processes. This is because physical processes tend to increase the disorder or randomness of a system. For example, when a solid melts into a liquid, the molecules become more disordered and the entropy increases.
What factors affect entropy changes in physical processes?
The main factors that affect entropy changes in physical processes are temperature, pressure, and the number of particles in the system. Generally, higher temperatures, lower pressures, and larger numbers of particles lead to higher entropy changes.
Can entropy be negative?
Yes, entropy can be negative in certain cases. This occurs when a physical process causes a decrease in the disorder or randomness of a system. However, the total change in entropy for a system and its surroundings will always be positive due to the second law of thermodynamics.
How is entropy related to the second law of thermodynamics?
The second law of thermodynamics states that the total entropy of a closed system will always increase over time. This means that in any physical process, the total entropy of the system and its surroundings will either increase or remain constant. Therefore, entropy is closely related to this law and is often used to explain and predict the direction of physical processes.
  • Thermodynamics
  • Materials and Chemical Engineering
  • Thermodynamics
