How to Calculate Acceleration and Average Speed in a Road Test
  • Thread starter Thread starter chaos17
    Dimensions Motion
To calculate acceleration in the road test, the car's initial velocity is zero, and using the formula x = ut + 0.5at², the acceleration is determined to be approximately 2.34 m/s². For average speed, the total distance covered includes both the acceleration and braking phases, but the user struggles with calculating the deceleration and final velocity during braking. The average speed can be computed by dividing the total distance by the total time taken, which includes both the acceleration and braking times. Further assistance is requested to clarify the calculations for part b. Understanding both acceleration and average speed is crucial for accurately analyzing the car's performance in the test.
chaos17
In a road test,a car was uniformly accelerated from rest over a distance of 400m in 18.5s. The driver then applied the brakes, stopping the car in 4.9 s with constant deceleration.
a) calculate the acceleration of the car for the first 400m.
b)Calculate the average speed of the car for the journey covering both the acceleration and braking distances.
v=d/t
avg speed=distance / time
a)v=d/t
v=400/18.5
=21.62ms^-1
b) I have no idea, I don't know what to do. Could someone give me a hint on what values to use or what formula to use.
Is my part a right?
what i mean by part a being right is that do i then use v to work out acceleration? Or is this a wrong way?
From what I can see, part (a) is right. The first thing that would be good to do is, to split the acceleration and the deceleration sections up. As you know the velocity of the first part, you need to find the velocity of the second part. How would you go about doing that, as you have the time and the initial velocity of the car, but you do not have the deceleration, final velocity or the distance the deceleration acts over. You do not need to know all everything, just enough to find out the average velocity over the whole[b/] time.
In reply to second post by Chaos: I believe you are on the right track. What equation do you use to then work out acceleration, when you have the velocity, time and distance?
I would them use avg acceleration= change in velocity / time.
Now that I think of it, wouldn't part a be:
u=0, t=18.5, x=400
x=ut+0.5at^2
so 400=0.5 * a * (18.5^2)
a=400/171.125
a=2.34m^-2
I think that is right.
But them what do I do for part b.
can anyone help for part b?
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
