Thread Closed
Nuclear Physics, portons and neutrons
Share Thread
Apr21-09, 09:59 PM   #1
You have 10 protons and 10 neutrons to paly with (mass of oxygen = 15.994915)
a. What is the mass of an oxygen nucleus that you build with equal numbers of protons and neutrons?
b. What is the binding energy of this nucleus?
2. Relevant equations
E=mc^2
3. The attempt at a solution
for a.
There are 8 protons in an oxygen, so 8 neutrons as well. Thus...
16(1.67x10^-27)=2.672...x10^-27
in us its about 16.096u...isn't suppose to be exactly 16, or is it close enough?
for b.
E=mc^2- except m is the change in m, so would it be 16.096-15.994915?
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Apr21-09, 10:42 PM   #2
You are right!
minor things:
mass of neutron at rest and proton at rest are not exactly the same.
However, In three significant figures, it is 1.67 E-27 kg, so you are right.
for b,
E='delta'mc2
delta mass means change in mass, change is always calculated as final minus initial
so its mass final minus mass initial
hence change in mass is actually 15.994915 - 16.096 = -0.101085 u
and binding energy is -0.101085*c2
Binding energy is minus, because the question is done in terms of energy loss
due to mass loss of the nucleons.
If the question is asking "how much energy is needed to break the nucleons in an oxygen nucleus apart", hence the mass final (when the nucleons are free) will be bigger than initial (when the nucleons are bonded together). And in this case energy will be positive (as energy input, not loss).
Apr21-09, 10:56 PM   #3
Thanks so much!
Thread Closed
Tags
neutrons, nuclear physics, protons
Similar Threads for: Nuclear Physics, portons and neutrons
Thread Forum Replies
is possible some elements absorb neutrons, without any nuclear reaction? High Energy, Nuclear, Particle Physics 8
Nuclear Physics Introductory Physics Homework 4
a nuclear engineering course as a substitute for nuclear physics?? Academic Guidance 1
accelerating neutrons, production of ultracold neutrons High Energy, Nuclear, Particle Physics 8
