| Thread Closed |
Battery charging via Solar pannel |
Share Thread |
| May7-09, 10:51 AM | #1 |
Hey guys, I recently conducted an experiment which involved charging a battery via a PV module and also logging the I and V values to calculate conversion efficiencies. I also logged the I and V values from two other circuits with a fixed resistance. I understand that every irradiation has a Maximum Power Point (MPPT) so a fixed resistance will never draw the maximum energy yield from the PV module. But when I saw the results I saw that the power conversion for the battery was good under high and low irradiances. My question is why is this? Does a battery have some sort of control circuit to vary its resistance ? Thanks in advance.
| May7-09, 12:06 PM | #2 |
Recognitions:
No, but depending on the battery type the terminal voltage and so the current availabel from the PV will change as it charges.
For everythign you want to know about batteries see here http://www.batteryuniversity.com/ |
| May8-09, 09:08 AM | #3 |
I've looked through that but I still don't understand what is actually happening.
| May8-09, 09:47 AM | #4 |
As long as the PV output voltage is higher than the battery it will charge the battery. When the PV output drops, the battery will drain through the PV circuit. Many sailors have woken up to find drained batteries from either leaving their solar charger on at night or not installing diodes to keep the current flowing only to the battery.
Are you certain that durring the low irradiance test the battery was not what you measured for power conversion? |
| May8-09, 02:32 PM | #5 |
| Thread Closed |
Similar discussions for: Battery charging via Solar pannel
| Charging Capacitor with 12v battery | Electrical Engineering | 12 | ||
| battery charging of cell phone using solar energy | Electrical Engineering | 2 | ||
| Charging A battery question. | Introductory Physics Homework | 3 | ||
| Max charging for SLA battery? | Electrical Engineering | 12 | ||
| Max charging for SLA battery? | Engineering Systems & Design | 1 | ||
