Ball Bearing Surfaces: Does the Ball Touch Both Races?
In ball bearings, the balls do indeed touch both races, which raises questions about how they can turn without dragging. The mechanism allows for rotation because, ideally, there is no sliding between the balls and the races. However, in practical applications, some sliding occurs due to factors like deformation or angular misalignment. Ball bearings are specifically designed to handle thrust loads in one direction, which is essential for their functionality. Understanding these dynamics is crucial for effective bearing design and application.
DecayProduct
Do the balls in a bearing actually touch both races? If so, how does the thing turn? Won't the balls be moving in different directions at each race, and therefore dragging against one?
There are two answers. In an ideal bearing, there is no sliding. In all real bearings, there is some sliding, but it is due to the deformation or angular mislaignment.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'What type of toilet do I have?'
I was enrolled in an online plumbing course at Stratford University. My plumbing textbook lists four types of residential toilets: 1# upflush toilets 2# pressure assisted toilets 3# gravity-fed, rim jet toilets and 4# gravity-fed, siphon-jet toilets. I know my toilet is not an upflush toilet because my toilet is not below the sewage line, and my toilet does not have a grinder and a pump next to it to propel waste upwards. I am about 99% sure that my toilet is not a pressure assisted...
After over 25 years of engineering, designing and analyzing bolted joints, I just learned this little fact. According to ASME B1.2, Gages and Gaging for Unified Inch Screw Threads: "The no-go gage should not pass over more than three complete turns when inserted into the internal thread of the product. " 3 turns seems like way to much. I have some really critical nuts that are of standard geometry (5/8"-11 UNC 3B) and have about 4.5 threads when you account for the chamfers on either...
