Where Does the Pi Come From in Variable Acceleration Problem?
The discussion revolves around a problem involving a particle of mass m released from rest under the influence of a force that follows the inverse square law. Participants are tasked with understanding the derivation of the time it takes for the particle to reach the origin, specifically questioning the origin of the constant pi in the final expression.
  • Participants explore various methods to derive the time expression, with some attempting to integrate the equations of motion. Questions arise regarding the separation of variables and the handling of integrals, particularly concerning the appearance of pi.
The discussion is ongoing, with participants providing insights and corrections to each other's approaches. Some have noted potential algebraic mistakes and are attempting to clarify their reasoning. There is an acknowledgment of difficulties with certain integrals, and while some guidance has been offered, no consensus has been reached on the correct path forward.
Participants mention issues with indeterminate forms arising in their calculations, particularly in relation to the limits of integration. There is a focus on ensuring that the assumptions made about the variables and conditions are valid, especially regarding the behavior of the force as the particle approaches the origin.
frankR
A particle of mass m is released from rest at a distance b from a fixed origin of force that attracts the particle according to the inverse square law:
F = -kx^-2
Show that the time required for the particle to reach the origin is:
[pi](mb^3/8k)^1/2
I have no idea where the pi came from.
This is what I've done.
F=dp/dt
dp/dt=mdv/dt
dv/dt=d^2x/dt^2
m*d^2x/dt^2=m*dv/dt
m*d^2x/dt^2=-k/x^2
m*x^2*d^2x=-k*dt^2
m[inte][inte]x^2dxdx=-k[inte][inte]dtdt
After solving the double integrals and pluging in the constants I get.
t = sqrt[-1/(6k)*m(16b^4)]
I'm going to be really embarrased if my calculus is wrong.
So am I doing wrong. I still have no idea where a pi comes from!
Thanks
Frank
Originally posted by frankR
m*d^2x/dt^2=-k/x^2
m*x^2*d^2x=-k*dt^2
Here's your problem. d2x/dt2 cannot be separated as dxdx/dtdt.
You'll have much better luck by noting the following:
a=dv/dt
a=(dv/dx)(dx/dt)
a=(dv/dx)(v)
or
a=v(dv/dx)
Now, try that with your force:
-k/x2=mv(dv/dx)
(-k/x2)dx=mvdv
You can get x in terms of v, and then simply note that v=dx/dt and integrate again to find the time. Give it a shot and let me know if you need more help.
edit: fixed an omission
I get -b*sqrt(2)/(3*sqrt(k/(b*m)) = sqrt(2*b^3*m/9k)
I still don't see where a pi could come from.
Can you show your work? That will help a lot!
Here's how I started:
-(k/x2)dx=mvdv
(sorry, I accidentally left the 'm' out in my last post, but I have fixed it)
-k[inte]bx(1/x2)dx=m[inte]0vvdv
(k/x)-(k/b)=(1/2)mv2
Are you with me so far? If so, can you show me how you did the second integral?
Except for up to there. I made an algebriac mistake.
k/x - k/b != k/(x-b)
Let me start over. Give me a couple minutes.
Thanks for your help so far.
Okay cool.
The integral ins't too prety so I let me Ti-89 solve it.
I get t = -Sin([oo])b^3/2*sqrt(2m)[pi]/4sqrt(k)
Which is = [pi]sqrt[Sin([oo])*b^3m/8k]
What the heck does Sin([oo]) mean?
Thanks. I just need to slow down. Stop making dumb mistakes!
I need to stop forgetting that chain rule property.
Thanks a lot!
Frank
Uh-oh.
It sin([oo]) is indeterminate, because it keeps oscillating. That means you can't assign a value to it. Me smells a mistake here.
Uh-oh.
I'm it's the software in my calculator.
I get a headache looking at this integral:
sqrt[m/2][inte]dx/sqrt[k/x-k/b]
I'm sure it's not as hard as it looks. I can drag up my old Calculus text, or look for a tabulated solution, to solve it another way.
I would try to work it into a form that matches an integral in a table. My guess is that it will turn out to be an inverse trig function, which is how you will get a π out of it.
I've been playing with it for half an hour, I'm not getting anywhere. It's beyond my mathematical abilities. Everything I do I still get an indeterminate solution.
If b>0, which it is, then I believe we get a solution.
Without knowing what you've done, I really can't say much on this.
Physically, you should get a solution, because this force is the same as a point mass or a point charge. Mathematically however, there seems to be a problem, because you encounter an integral like this:
[inte]b0((x/(b-x))1/2dx
whose integrand diverges at the lower boundary. Still, there should be a way to handle this improper integral.
That's the form I found.
If x is under the following condition:
0<=x<b
The solution is fine.
  • · Replies 41 ·
  • · Replies 16 ·
11K
