What is the particular integral for y''+y'+y=xe^{2x}?
  • Thread starter Thread starter Air
    Integral Ode
The particular integral for the differential equation y'' + y' + y = xe^{2x} can be determined by using the method of undetermined coefficients. The appropriate choice for the particular solution is y = (A + Bx)e^{2x}, where A and B are constants to be determined. This approach leverages the linearity of the differential operator and the properties of exponential functions. For cases involving terms like x^2e^{2x}, the solution extends to y = (A + Bx + Cx^2)e^{2x}.
  • Understanding of linear differential equations
  • Familiarity with the method of undetermined coefficients
  • Knowledge of exponential functions and their derivatives
  • Basic concepts of linearity in differential operators
  • Study the method of undetermined coefficients in depth
  • Learn about the application of Leibniz's rule in differential equations
  • Explore variations of particular integrals for higher-order differential equations
  • Investigate the use of Laplace transforms for solving linear differential equations
Students and professionals in mathematics, particularly those studying differential equations, as well as educators looking for effective methods to teach solving techniques for linear differential equations.
Air
When finding the particular integral, I understand that for:
[tex]y''+y'+y=e^{2x}[/tex], One would choose [tex]y=Ae^{2x}[/tex]
[tex]y''+y'+y=x[/tex], One would choose [tex]y=Ax+B[/tex]
But what am I supposed to choose if I have: [tex]y''+y'+y=xe^{2x}[/tex]?
Well, you know that in case of:
Dy = exp(p x)
where D is a linear differential operator,
you would choose y = A exp(px)
You also know that a solution of:
Dy = f(x) + g(x)
can be obtained by solving
Dy = f(x)
and
Dy =g(x)
separately and adding up the solutions. Linearitity of D implies that this will work.
Then, in case of:
Dy = x exp(px)
you could simply consider the factor x to be the derivative w.r.t. p. So, if you simply solve:
Dy = exp(px)
by putting y = A(p)exp(px), then the linearity of D implies that the solution of
Dy = [exp[(p+epsilon)x] - exp(px)]/epsilon
is given by
[A(p+epsilon)exp[(p+epsilon)x] - A(p)exp(px)]/epsilon
So, taking the derivative of A(p)exp(px) w.r.t. p will do. By Leibnitz's rule, you see that this amounts to putting
y = (A + B x)exp(px)
[itex](A + Bx) e ^{2x} [/tex]<br /> <br /> for [itex]x^{2} e^{2x}[/tex] use [itex](A + Bx +Cx^{2})e^{2x}[/itex]<br /> <br /> and so on[/itex][/itex]
  • · Replies 18 ·
