Moment of Intertia, proving Parralel axis theorum. Help please.
The discussion focuses on calculating the moment of inertia (I) for an equilateral triangle rotated about the z-axis, with a constant depth (d). The initial calculations involve integrating to find I using the density (p) and volume (V) relationships. A new scenario is introduced where the triangle's vertex is displaced from the z-axis, leading to a piecewise function for B(r). The user seeks guidance on generalizing the method for various shapes and questions the validity of their approach, emphasizing the need for a clear understanding of the moment of inertia as a vector quantity. The conversation highlights the complexities of applying the parallel axis theorem in this context.
Starwatcher16
Imagine we have a Equilateral triangle in the xy plane with one vertex at the origin. The triangle will be rotated about the z axis. The depth of the triangle, d, will be constant.B_r=B(r)
From the picture I see that B_r=\frac{r}{h}B , V=\frac{B_rhd}{2}=\frac{Bdr}{2}
First, I need to find I.
<br /> I=\sum M_i*r_i^2=\int r^2 dm. p=M/V, so, dp=p dv
<br /> I=p\int r^2 dv Substituting usingdp=p dv and dv=\frac{Bd}{2}dr, we get:
<br /> I=\frac{pBd}{2}*\int r^2 dr=\frac{pBd}{2}*\frac{r^3}{3}. Using p=M/V:
<br /> I=\frac{Mr^3}{3h}=\frac{Mr^2}{3}. R_total/h=1.
Now, let's say I want to find I for the same shape, but now there is a distance d from the vertex to the z axis.
Everything is the same as the above, except, B_r is now a piecewise function, where B(r)=0 for r<d and B(r)=B_r=\frac{r-d}{h}B for r&gt;d.
Reworking it with the new B_r, I can get the new I. After that I just solve for x in I_2=I_1+x to get the parallel axis theorem.
The thing is, I don't know how to generalize this one example to work for all shapes. Any help is appreciated.
Lets pretend that whoever answers my question get free cookies.
Also, now that I think about it, I am not sure this method is valid.
Yes picking a shape will not help you prove the theorem. What is the definition of the moment of inertia? Note that it is a vector quantity. Now displace the axis a distance d away from the original axis, note that d is a vector too.
TL;DR Summary: Find Electric field due to charges between 2 parallel infinite planes using Gauss law at any point Here's the diagram. We have a uniform p (rho) density of charges between 2 infinite planes in the cartesian coordinates system. I used a cube of thickness a that spans from z=-a/2 to z=a/2 as a Gaussian surface, each side of the cube has area A. I know that the field depends only on z since there is translational invariance in x and y directions because the planes are...
