Differential Equation using Integrating Factor
CFDFEAGURU
The ODE is
(1+x)*dy/dx - xy = x+x^2
The method of solution is to be through the use of the integration factor.
First, I divided each side by (1+x) to produce
dy/dx - xy/(1+x) = x
then factor out the x on the LHS to produce
dy/dx - x * (y/(1+x)) = x
then divide both sides by x to produce
dy/dx - y/(1+x) = 0
now move the -y/(1+x) to the RHS to produce
dy/dx = y/(1+x)
That is all the farther I have progressed. Am I correct so far?
Thanks
Matt
Yes, you are correct so far by what progress is that? How does that help you find the integrating factor?
The left side of your equation is (1+x)(dy/dx)- xy. The whole point of an "integrating factor" is that it is a function u(x) such that u(x)(1+x)(dy/dx)- uxy= d(u(x)(1+x)y)/dx.
Go ahead and use the product rule on the right side. That gives u(1+x)(dy/dx)+ u(1)y+ (du/dx)(1+x)y and that must be equal to u(x)(1+x)(dy/dx)- uxy. Well, the "u(1+x)(dy/dx)" cancels immediately leaving u(x)y+ (1+x)y(du/dx)= -uxy so (1+x)y(du/dx)= -xy(1+ u). Now the "y"s cancel so (1+x)(du/dx)= -x(1+u) which is a separable equation. du/(1+u)= -dx/(x(1+x)). Integrate that to find the integrating factor.
By progress, I was meaning the reformatting of the original equation. I believed that this equation is seperable but the assignment was to use the integrating factor method.
I would rather take the path of the seperable equation.
Starting with
dy/dx = y/(1+x)
multiplying both sides by dx produces
dy = y/(1+x)dx
dividing both sides by y produces
dy/y = dx/(1+x)
integrating both sides produces
ln(y) = ln(1+x) + c
Is this correct so far?
Now proceeding forward with your instructions to integrate
du/(1+u) = -dx/(x(1+x)
upon integration of both sides
ln(1+u) = -ln(x)+ln(1+x)
now the integrating factor would be
e^(ln(1+u))
upon integration would be
1+u
Thanks
Matt
OK. I think I have the solution.
With the integrating factor of 1+x and using the equation
dy/dx -y/(1+x) = 0
multiplying both sides by the integrating factor produces
(1+x)*dy/dx - (1+x)*y/(1+x) = 0
which is equal to
(1+x) * dy/dx - y = 0
upon integrating
(1+x)*y = c
solving for y produces
y = c/(1+x)
Am I correct?
Thanks
Matt
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
