Sandbag dropped from balloon - find final velocity
The discussion focuses on calculating various parameters related to a sandbag dropped from a hot-air balloon. The balloon ascends at a vertical speed of 2.50 m/s and experiences a horizontal wind of 1.10 m/s. Key calculations include the horizontal displacement of the balloon, the distance from the launch site where the sandbag lands, the time taken to reach 205 m, and the final velocity of the sandbag. Participants are encouraged to share the equations used for their calculations to clarify the results. Accurate calculations are emphasized over guesses, highlighting the importance of understanding the physics involved.
Chupu
1. Experiencing a constant horizontal 1.10 m/s wind, a hot-air balloon ascends from the launch site at a constant vertical speed of 2.50 m/s. At a height of 205 m, the balloonist maintains constant altitude for 10.0 s before releasing a small sandbag. What is the horizontal displacement of the balloon? How far from the launch site does the sandbag land? How long it takes the balloon to reach the 205 m? What is the final velocity of the of the sandbag?
Thank you guys :)
My guesses are the
horizontal displacement: 190m
how far from launch site: 180m
the balloon took: 82s
the final velocity: 6.018m/s
Why guess? All of these things are exactly knowable. What equations did you use for each result?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
